Hey guys sorry about another fuel economy thread, but this one is specific to my car.
Im only getting around about 190kms per tank of 98 octane fuel (220 maybe till dry -- no highway kms, alot of short trips) and i was wondering if thats normal for what I have done to the engine.
Here is every modification done to the car
•CP Forged Pistons
•Eagle Rods
•Tomei Metal Head gasket
•Extensive Head Work
•N1 Oil Pump
•N1 Water Pump
•Nismo Thermostat
•HKS Step 1 Cams
•HKS Cam Wheel
•Z32 AFM
•HKS GTRS Turbo (set at 10psi low boost, 14psi mid boost and 18psi high boost)
•555cc Injectors
•Bosch Fuel Pump
•Split Fire Coils.
- Front Mount Intercooler
•Tein height adjustable coilovers
•Cusco Front Strut Brace
•DBA4000 slotted rotors front and rear
•DS2500 front brake pads, •RACEBRAKES rear brake pads
•GFB Stealth Fx blow off valve
•3inch split dump/front pipe into 3inch CATCO hi flow cat continues into 4inch through to 7inch cannon with 5inch tip
•Power FC & Hand Controller
•Apexi AVCR Boost Controller
•Apexi Turbo Timer
•Apexi pod filter
•C’s shortshift kit
•Excedy 5 Puk Ceramic clutch
I set my BOV to about 1/3 in the atmosphere but i doubt thats the main reason why it consumes that much fuel...
And I'd say Im a mix between crusiing and spirited driving.
Cheers
tune related or leaking injectors maybe
get it into a good tuner
dunno how much power you are making but im pretty sure e85 users are getting better fuel economy than you are
Its making 278rwkw, well unigroup were the last tuners to tune it, so i guess something happened between the last time it was tuned and now.
So I'll let them have a look at it.
Thanks for the quick reply mate !
depends on how hard you flog it
how are the afr's cruise for light load - air fuel ratio or it just a max power tune (most are)
does your 02 sensor work (most die after a few years)
is 02 feedback turned on
Sorry mate but what do you mean by 'cruise AFRs' ?
And yes im pretty sure, as it makes no bov noise at all when set at minimum.
Cruise AFR (Air Fuel Ratio) is the fuel ratio when you are cruising along at say 60km/h with minimum load on the engine. If the car runs rich at these points your fuel economy will be shocking (as this is where you will most likely be spending most of your time)
Got a dyno graph that shows the AFR's of the power run as well, if this is rich and your flogging it everywhere then this will have a pretty bad effect on economy, but seen as you wont be going for fuel economy while loading it up, i think the issue would more be cruise AFR's
I get about 500-600kms a tank on my 25. When driving sensibly on highway. When I drive it on track i can get around 200 per tank! On road driving a bit harder between 450-500. I dont run it under 1/4 usually though. I think, (dont quote me) my cruise afr's are around 17-18?? rings a bell anyway.
Im getting a bit more fuel added on cruise next time as it doesnt do plugs alot of good when doing big kms on highways etc.
Well im usually running low boost (10psi) and here or there ill run it on high boost for abit of spirited driving
I actually dont know, since I've bought this car pretty recently about 2 months ago and the previous owner got it tuned at unigroup before he sold it (have receipts).
unigroup are supposed to be really good i believe
something is definitely up, i'd go back to unigroup and ask them to look into it
was it always this bad?
Yeah exactly, same from what Ive heard aswell. I will ask them to have a look anyway :) Since i bought the car two months ago it has always been like this.
Oh ok well thats something I'll check with unigroup .. but i have a feeling it may be this, thanks for the explanation. Plus there is barely any turbo lag, so im always boosting, even when i take it easy.
Thanks for all the replys.
I would have thought 278 was high for a GTRs but anyway .
Nismo thermostat ? Possible cool running not helping .
3" into 4" exhaust , big pipes particularly if they increase down the system often allow reversions and cost low end torque , and consumption .
Personal bias but I dislike split dumps because the gates tube is often too small and reintroduces at stupid angles .
My experience with button clutches in road cars is the need to rev them to get them moving , consumption ?
Your call but you may have overkilled in a few areas .
Please tell me your static CR is not a lowly 8-8.5 to 1 , cheers A .
^^ 278rwkw on 98ron on Unigroup dyno??
I would like to see a print out of that run.
Definitely an issue with the car returning that sort of economy. If O2 feedback is switched off with a Unigroup tune it still won't return that sort of economy. There is another issue IMO.
I have a big folder of reciepts from the previous owners, performance wise I'm going off a dyno dynamics dyno sheet which is the latest dyno sheet I can find. If I find the uni group one I'll post it up tomorrow. Why does that power figure sound surprising ?
Well hopefully it's not a big issue, the car seems to run 100% there's nothing unusual that happens when i drive.
lol..im getting 350 on each tank with a mix of highway and wot at 1.2bar Eflex :yes:
what temp does a nismo thermostat open at? does it get up to correct temperature?
Edited by SliverS2
If all your "short trips" are less than 5mins, then that's of little surprise given the car is on cold start the entire time.
Otherwise it's as simple as the tune or something related to that - is up the creek.
Or you just need to learn to drive more economically.
It can only be those really.
I doubt it's the coilovers or Ferodo brake pads causing the problem.
You really shouldn't be playing with the BOV if it's got a tune. It's going to be a combination of things that is the cause for the bad fuel economy. A possibility that hasn't been mentioned is the coolant temp sensor, without a working one it will be stuck in cold enrichment and chew through fuel.
What would playing with bov do for the tune at all?
Unless your running a afm obviously
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
