Hi,
I have a S1 260RS Stagea and have Xenons in the car. They are Xenons/HID for both highbeam and normal beams.
Im not sure if they are a genuine Nissan item or after market. How do i tell?
The issue is;
i turn my headlights on and while im driving even over bumps and railway tracks etc the headlights stay on and solid even though i have lowered suspension.
However when i hit the brakes and the front end dips the drivers side head light starts to flicker and sometimes turns off. The harder i brake the greater the chance the light turns off.
Also, it seems that once the headlights have been on for some time the light seems to resist the braking action more. So i have to brake harder to get the light to turn off but it still flickers under light braking. When the lights are cold even the slightest braking action manages to turn it off.
Any ideas on what is causing this? it drives me nuts
https://www.sau.com.au/forums/topic/412361-s1-stagea-headlight-issue/
I dont think u'd need to rip it all out. Locate where the ballasts have been installed and check they arent just floating around in there. Then check all the wiring where its been modified. Check for continuity too. U prob find something is loose or damaged. U'd b surpised how bad some peoples wiring jobs are.
Hahahaha Thanks for the advice. Ill do continuity checks, im sure thats probably the issue. As for peoples wiring jobs i know what you mean. I have seen some wiring that just makes you want to put the panels/trim back on and walk away. LOL
    • I also built one, for a bit of a laugh. Pretty happy with it. Basically, obtained a clear garnish, painted it sanded back the paint off the letters, clear coated it. Inserted a 3cm EL strip through a slot I created in one end and sealed it up.
    • Apexi SAFC - AFC 1st Generation Rare Old School JDM As you can see it all lights up in the photos and is in 100% working condition. Has been kept in storage and boxed for years there won’t be to many like this if any! Especially with all original packaging and manual. price:$650   APEXi SAFC 2  In Complete Working Condition Refer To Photos and view the video provided.  Price:$500   Located Melbourne - Australia Wide Postage Available At Buyers Expense  IMG_6981.mov
    • wow so i just logged back in after buying the 33 and joining SAU, And I've got all a whole bunch of you wanting to know more, well unfortunately it still doesn't run i was hoping it was seized from a snapped timing belt as i turned it over by hand and it was fine and then it did a few revolutions and jammed solid when i was running it with the key, so the timing belt is mint, I've also found a lot of the parts I'm removing have already got bolts undone or not quiet tight enough to be unsuspicious. so the plan is to find a running RB30 block and chuck my head on it.  I have a habit of buying stuff I don't need or require so for my none running engine i have a forward facing plenum , Apexi power fc, 40mm Turbosmart wastegate, And for the car its self coilovers ,low seat rails and BRZ seats (black seats with red stitching i already had these and they are ADR Approved and allow rear passengers access)
    • I took apart the dash and found this strange 2 pin connector. it dosen't seem like its factory or oem, any clue on why someone would add it and where it might have been connected too?
    • Not mention a SS2 especially with that rear oddly small rear housing. I feel the Facebook mechanics and experts has led OP in the wrong direction.
