Hey everyone, my car is tuned like shit at the moment, but it's going in for a tune next week. I've been reading up on AFR's and it seems at idle it is really lean. Could this explain why it's hard to start?
Would you guys advise not to drive the car too much before it's tuned?
The car is a Z32 TT.
https://www.sau.com.au/forums/topic/412369-how-bad-are-these-afrs/
Point 1: There is no idle AFR shown on that dyno chart. The run starts at 55 km/h.
Point 2: The AFR starts at about 15:1 at cruise (in 3rd or 4th or whatever gear the run was done in) which is ever so slightly lean but otherwise pretty normal.
So , no. I see no problem there.
Point 3: The AFR is perhaps ever so slightly lean in the region around 135km/h, which is near peak torque, right in the fat of the midrange. If it is going to ping, it will do so there. 12.5:1 is probably safe, but depending on the engine, might be a little too lean. But not a massive problem. I would say, given that it is richer at lower and higher revs than that, it could easily be tuned to flatten out the AFR in that region, should you want.
All seems OK but could use with some touch ups here and there (depending on the motor and its sensitivity to detonation)...
Especially rolling onto peak torque as this is where the motor will have the greatest tendencey to ping/knock. 12:1 is OK but depending on the application, I'd be tempted to go a little richer.
As for idle, the dyno graph gives no information so cannot comment.
EDIT: GTSBoy beat me to it...
Edited by R32Abuser
I would make it a tad richer (11.5:1) as it approaches MBT (max torque) then bring it back to 12:1 all the way to the rev limiter.
EDIT: R32Abuser beat me to it
Edited by johnnilicte
MBT is not an RPM specific thing, and 11.5:1 is quite rich for a low compression motor running 6psi...
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 😛
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
