Hey everyone, my car is tuned like shit at the moment, but it's going in for a tune next week. I've been reading up on AFR's and it seems at idle it is really lean. Could this explain why it's hard to start?
Would you guys advise not to drive the car too much before it's tuned?
The car is a Z32 TT.
https://www.sau.com.au/forums/topic/412369-how-bad-are-these-afrs/
Point 1: There is no idle AFR shown on that dyno chart. The run starts at 55 km/h.
Point 2: The AFR starts at about 15:1 at cruise (in 3rd or 4th or whatever gear the run was done in) which is ever so slightly lean but otherwise pretty normal.
So , no. I see no problem there.
Point 3: The AFR is perhaps ever so slightly lean in the region around 135km/h, which is near peak torque, right in the fat of the midrange. If it is going to ping, it will do so there. 12.5:1 is probably safe, but depending on the engine, might be a little too lean. But not a massive problem. I would say, given that it is richer at lower and higher revs than that, it could easily be tuned to flatten out the AFR in that region, should you want.
All seems OK but could use with some touch ups here and there (depending on the motor and its sensitivity to detonation)...
Especially rolling onto peak torque as this is where the motor will have the greatest tendencey to ping/knock. 12:1 is OK but depending on the application, I'd be tempted to go a little richer.
As for idle, the dyno graph gives no information so cannot comment.
EDIT: GTSBoy beat me to it...
Edited by R32Abuser
I would make it a tad richer (11.5:1) as it approaches MBT (max torque) then bring it back to 12:1 all the way to the rev limiter.
EDIT: R32Abuser beat me to it
Edited by johnnilicte
MBT is not an RPM specific thing, and 11.5:1 is quite rich for a low compression motor running 6psi...
    • My fob has never worked, I once attempted to follow the procedure to re-key it, (I have other fobs for the car alarm thing in there). I actually have three of them. Do aftermarket alarms take over the pairing mechanism for central locking? Or do they piggyback off it? I suppose it depends on the system, right? I have four sets of keys/keyfobs. One definitely works, one I think works, one definitely doesn't work, and I have the OEM one that has never worked :p. Is this fixable/workable/whatever? I mean I know it's beyond "just clean it" but how *do* they get synced up?
    • It's actually a really weird comparison... the MX5 is on another level and I kinda question this comparison at all. It'd be closer to compare it to a GTI/Golf/Hatch anything that kicks around. NC MX5 with a turbo has the right to go up with and beat the FD RX7 or 180SX or any other JDM hero car. That's the comparison that would really ruffle feathers.
    • @MBS206 you need more shed in your life... What sort of car is your mates race car?  Hopefully he returns the favour when you're ready to get cracking on yours! None of my mates are into cars so I don't have to worry about that as a distraction thankfully.  I have enough other distractions so I don't need that one too!  Between working 6 days a week (5 1/2 really so 55 hours or so per week), both kids have basketball almost every week night (including Friday night in Melbourne - 2 hours away), my daughter plays netball as well, my sons footy has started now and I coach his under 14's side as well as I'm on the Footy club committee this year, I ride motorbikes every spare Sunday I can find, plus trying to be some sort of a husband.  Life is a busy little exercise at the moment!  I wish there were 8 or 9 days in a week sometimes!
    • Ha ha, that is very true!  I'm too scared to leave it in the position though, it tingles my balls seeing it like that!
    • Which one did you buy? I have always wanted a decent inspection camera but have been unable to tell whether something is cheap junk or cheap junk chunk sold at just a bigger markup
