I bought the car as a shell and built it from there. Huge list of modifications do not want to know price to build car 95% of all parts purchased brand new. This car drives amazingly and is a complete animal, not to mention has the looks to match. You will notice in the pictures the unfinished front guards. This is due to not having wheel lips for my 18" equips, so i never got around to completing a set. Some aggressive FRP guards could be bolted on to set it right off ! Car is always looked after / garaged and serviced only with Mobil products. Also gets plenty of attention at the track =P
I too have no problem sending this interstate I've used a very good company before bringing a car up from VIC.
Price = $22000
Engine - Build Buy KJ Motor Machining, Kohen builds drag racing engines to blueprint with extreme tolerances, the motor cost a f**ktonne.
The car had no Odo, but it wouldn't even be close to 5000km, gearbox was rebuilt at same time as motor. It was also built for 30psi roughly 600HP.
Mahl pistons
Scat rods w arp fasteners
Mls headgasket
Acl mains
Arp big end fasteners
Arp head fasteners
Arp main fasteners
Ati balancer
Supertech valve springs
Re-welsh plugged
Tourqe plate honed to .20thou
Oil galleries drilled larger / tapped
Valve seats re-cut / valves faced
Crank collar welded / machined / re-ground
Block n Head re-faced
Balanced, Rotated n blueprinted.
Head ported / knife edged
Garrett Gt3076 .8 (rebuild by garrett when engine was built)
Hks 264 9mm cams non-vct
6boost forward highmount - head wrapped
Turbosmart 38mm Wastegate
Freddy plennum faced and port matched
Decs 550cc inj
Q45 TB
Carbon Fiber Cam cover & plug cover
Nismo FPR
Mezier waterpump (controlled by haltech to act as thermostat)
NPC lighten flywheel n 5 puck cushion
Rebuilt 25box
PWR xflow GTR radiator
PWR custom Intercooler
PWR oilcooler w. Enzed Lines
PWR powersteering cooler
Motor into firewall 1.5 Cyl
Fuel cell w. Surge & Dual Walbro pumps
1.5 to 2" screamer pipe
Full 3" Exhaust wrapped
Extreme Custom Engineering 2x4" twin tip exhaust
Suspension
PBM Coilovers 10/8
PBM LCA front / rear
PBM toe
PBM camber
PBM castor
PBM traction
PBM cradle risers
Driftworks Hubs (modified for dual caliper)
Whiteline Adjustable sway bar front / rear
Extreme Custom Engineering catch can, with drainback
Drivetrain
rb25 box (rebuilt same time as motor, new 3/4th synchro & bearings all round) by DANSTRANS
Urethane Mounts
npc lighten flywheel
5puck clutch
Quartermaster hydraulic throwout bearing
Hardy Spicer 1 piece tailshaft
Kaaz 2way
R33 Gtst Brakes w. DBA rotors w. QFM pads
Dual Calipers for separate Hydro
Electrics
Haltech PS2000
Racepak IQ3
Wideband Controller w. Sensor
Boost Control Solinoid
Oil Pressure
Oil Temperature
Water Temperature
Air Temerature
3bar Map Sensor
Haltech TPS Sensor
Standalone LS1 coilpacks with custom Eagle plug leads
MR2 Electric Power steering pump mounted in boot.
Single engine loom plug on firewall
Full rewire with a EZ kit
Switch panel's control everything
Exterior
Onevia Conversion
Tinted red taillights
Dmax type 3 kit
Dmax type bonnet vent
Dmax roof lip
Custom Metal Widebody
Painted Black
Interior
Bride ZetaIII drivers seat
PBM hydro w. Tilton master
S15 Dash
Tilton floor mount pedal box w. Tilton masters
Chassis
Fully Stitch welded, underside aswell
Rear firewall, due to fuelcell
Notched firewall for motor to sit back 1 1/2 cylinders
Framed rear end, for fuel cell
Huge front tubs
Rear Tubs w. metal widebody
Tubed front Reo, sits tight in frontbar
Wheels
Front - 18x8.5 SSR Vienna
Rear - 19x10.5 +12 Varrstoen (x4)
The work equips are not included in the price but could be negotiated.
Power
450rwhp @ 17psi tuned by Chris @ Bob Romano's
Spares
2 x 5bolt drive shaft
4:1 Diff gears w. housing
2 x Tilton master cylinders
Tilton Remote brake bias adjuster
Steering Rack
Whatever else i can find for it
Pictures
I'm sure there is allot I've forgotten i can be reached on 0420 855 181 if you have any questions or want to check it out. I will continue to drive this at the track until sold.
I've f**ked up the price its $19,500 with the SSR Viennas / Varstoens.
$22,000 with the equips (18x9.5 front 19x10 rear) there not shown in the photo, will have updated pics soon.
chrome equips 19x10 19x11 are $2800 extra
great build.... very impressive sad that u want to sell her.... off topic i know but did the stiching the rear make a difference ?
whole things stitched, only time u no the difference is when you jack one corner it goes up level and u can balance wheels opposite corners on curbs, not that i can get this out my driveway =[
would make an awesome car for competition, hopefully have some decent pictures up within a few weeks, got a bloke wanting to shoot it =P
This is the hottest car i have seen on this forum. id buy it for 22 tomorrow!
and you haven't contacted me why? haha
if your actually serious and not just slinging jokes call me 0420 855 181
peace
sorry maybe i shouldve worded that better. id pay 22k for that tomorrow as in, i think its worth that and if i had 22k id come and buy it, congrats on building such an epic car, but i dont have 22k to come down and get it!
bump, can do an extreme package
car + 8 work equips + 4 varstoens + dual axle trailer (tyre rack, elec winch, toolbox) = $29,000
will include every Nissan part and car related parts i own.
  • 1 month later...
  • anyone wanna swap a basic s13 or s14 + cash?
  • something along the lines of Sr manual, t28bb, coil overs, 2way, castor / camber / toe arms
  • 1 month later...
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
    • I dunno what the "best" one is....but when my 040 died late last year, after about 20 years of screaming service....I put in a 255. Like any such thing, you have to finagle it a little bit - it's not a no-brain swap. But it's not hard.
