Hi all,
i am selling my 1996 r33 sII GTST as I need to make room in my garage as I dont drive it enough, i can make it cheaper by removing some of my aftermarket parts but i will list what it has now,
1996 sII White in great condition with m spec kit and lip spoiler on front,
77000kms with japanese as well as aussie service history
17" works wheels with good tyres
lowered tanabe street suspension
tanabe jasma approved 3 1/2" exhaust from cat back
hks evc II boost contoller
hks turbo timer
ms intakes pod filter
blitz front mount intercooler
blitz b.o.v
ngk plugs and mobil 1 oil with nulon additives
GDZOOK number plates (son of godzilla)
Premier metal window tint
autometer boost and air fuel gauge mounted on auto meter pod,
auto italia steering wheel with proper airbag boss kit (spare airbag wheel)
Alpine cdr 7873
focal polyflex splits in front
apline r type splits in rear
kicker 12" sub in box
clarion 400w 4 channel amp mounted
response 450w rms amp for sub mounted.
Narva ultra white head light globes
it has a alarm with window closers and turbo timer control as well as separate 4 point immobiliser.
pics for stereo can be found here http://forums.skylinesdownunder.co....&threadid=11625
i am looking for $25500 as is or can be cheaper without stereo gear and gauges and hks stuff. also see attached pic can email more if anyone is interested.
Scott
0405-428-646
I will take $24500 this is a really good price for the car...the market must be bad atm cause ive had it at a car yard on consignment in the trading post for 6 weeks and only about 6 ppl have seen it...any hints from anyone...i had one good offer from here for 24k but i didnt take it but in hindsight i shouldve cause now ive spent more money on it...any hints are appreciated
Scott
gdzook,
lovely car... don't drop the price anymore unless your desperate, it should sell soon hopefully... for a series II and all those extras that is a very good price, good luck with the sale.
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
