R32 Gts-T
hi all i recently picked up a new project off a fellow member on here to set up for off street racing, drift, drag and track basically anything i can enter it in
Car: R32 GTS-T
Engine: RB20DET
Intake: HKS pod, ARC turn flow front mount intercooler
Fuel: GTR 444cc injectors and resistor pack, bosch 040 fuel pump
Exhaust: stock manifold, stainless dump pipe with screamer pipe, 3" Trust old school mild steel cat back with no mid muffler
Driveline: Exedy 5 puck button clutch
Suspension: FRONT: Nismo front strut brace with master cylinder stopper, JIC shortened upper camber arms, Kazama adjustable castor rods
REAR: Pineapples in the rear subframe
Brakes: stock
Wheels & Tyres: black R33 16s
Interior: GTR front seats
Body: fibre glass vented bonnet, bonnet pins
Stereo: none
only pics i have atm from before i picked it up it didnt come with the GTR wheels and the coil overs so its stock height il update with current pics once shes back together
no help? ok anyways how she looks now with gtr bonnet, 17s, rear camber arms and hicas and aircon removed and hicas lock bar added. also fitted up the tubo with some braided oil/water lines
Edited by DPB
  • 4 weeks later...
can anyone tell me how to edit my first post?
first post cant be edited
on another note the car is coming along nicely! vertex is by far the one of the best looking kits for the R32! if you dont want to run a vertex front bar run a GTR or GTR copy! suits well
best of luck on the build :D
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
