Bloody got back from a 5 day drive to melbourne and found my car had been stolen from work (where I parked it in a security gated car park). The gates weren't damaged and work failed to enform me that it had went missing until my return to find it not there. Please help, if you have seen or heard of anyone recently purchasing or aquiring a black r32 please pm me.
Details
1989 black r32 rb20det :
Dark windows (but not the rear)
Scrapes on the rear right quarter panel to the rear bar (was like that when I bought it :)
front right guard has 2 holes that have cable ties holding the bumper on.
smoked front indicators
standard r32 wheels
rear boot has plugs in it where spoiler used to be and have slightly corroded
lowered on tein coilovers
exhaust (unknown brand)
pics to follow...
I was in the process of tidying everything up and have most parts here to do so (which pisses me off even more).
Didn't have the money to get fully comp insurance so I'm on my own.
Thanks for reading mates
Sorry to hear man, sounds suss if the gates weren't damaged if that's the only entry point into the place and your work didn't let you know.. Ahhh no insurance! i feel for you man, hope it pops up :(
Plates were 036 RVW, gutting, feel like I have been raped. It'll be in some garage somewhere gtting broken into parts. :( If anyone sees anything please pm me. Also has a tail light out but doubt that helps. Thanks fot the support fellas.
Gotta love it when you work with the scummy pieces of shit that call this country home. No doubt it was one of them in on it and responsible for it.
I hope you find her or at least find the ones responsible.....i would also suggest changing jobs if possible too as the blokes you work for/with are obviously in need of a good thumping.
  • 1 month later...
i feel your pain mate.. (my GTR was stolen 3 weeks ago from melbourne) its a real keen sense of violation and betrayal. ESPECIALLY given your circumstances.. im sorry for your loss.
best of luck with finding it!
Dan
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
