Newcastle/central Coast Cruise To Broke And Back! 2/12/12
just called norm and hes keen, and ill add the other boys too :)
haha my gtt is that colour jayson, looks pretty nice in yours but i dont think im going to be to picky with the colour price, supporting mods etc will be my main aim as the budget isnt huge right now haha.
will have to have a chat with you at the cruise mate!
  • Replies 177
ATTENDING (28)
Ruxis- R34 GTT
GTR34A- R34 GTR
mjh- R34 GTT
Chookie- R34 GTT
Humbla- R33 GTST
BenRthirtyfour- R34 GTT
Gtraaron- R33 GTR
Tank- R34 GTR
Beenowened- R33 GTST
RB25 SKYLINE- R33 GTST
Chad_- R32 GTR
Wrximposter- 06 WRX
Danmc- 06 WRX
KURTIS34- More kw the mat 34 GTT (hehe)
The_wolf- n15 sss
WAGON_BOY- Stagea
FeZ25- R34 GTT
Terry_GT-R34- FOZ :(
Levinboy- R33 GTR
Sydking- R33 GTS4
gtraaron- R33 GTR
buba- R34 GTT
luke GTR- Mystery!
Jason- SUSHI!
Jayson- R33 GTR (NomNom)
Norm- R34 GTR
Gaz - Silver S15 with the shiniest wheels on the planet
Jack - Green R32
MAYBE
TimmyMA70- SSS PULSAR
Luke Gtr- R32 GTR
Levinboy- R33 GTR
ill bring sushi to this provided im not hungover as a mofo
that didnt stop u last time hahahaha
Ok so, for the guys from the coast, lets meet at 8am at the rest spot at ourimbah just before you go onto the F3 will take us around 35min to get to the meet point according to google maps so 8am meet leave at 8:20 give us 40min to get to the shell by 9am. Bring enough fuel to get you to the shell
https://maps.google.com.au/maps?saddr=Unknown+road&daddr=Freemans+Waterhole,+New+South+Wales&hl=en&ll=-33.333433,151.391129&spn=0.01929,0.042272&sll=-33.344637,151.371882&sspn=0.009644,0.021136&geocode=FQg4A_4dtq4FCQ%3BFWazCP4dvn0HCSmTKJ2YlzpzazEA7TIWaH0BBQ&oq=Ourimbah&mra=dme&mrsp=0&sz=16&t=m&z=15
Edited by T4NK
its come to my attention i have a flat tyre and no time to have it fixed :'(
even if i did, no driver cause mats going to geelong im fairly sure, who wants a farking passenger people? ill bring camera and shoot you ;)
Yeah ill be away mate, still have your stockies at home too if you need something to roll on............
Where will Sam be? Cant he drive you?
i got stockies too, i just cant do any lifting, managed to screw my shoulder up again :(
You noodle nut! The cruise is still a week or so away, i am sure you can get a stockie on the car by then, tell muscles (your mum) to do it :P And film it for the lolz!
im gunna attempt to get the flat (which was causing the shaky steering on way home) to the shop n get it fixed up cause i dont wana rep stockies up front i aint no honda civic burnout car!!! :ph34r:
Shouldnt have been the cause unless you had an Anvil in it lol....... It felt fine! Admittedly i was nearly asleep for most of that drive :ph34r:
Anyway i better GTFO this thread as i am no longer welcome lol :P
no stay we can be whores n shit like old times :D
lotsmorehomo? lol
Yeah its been a while since i have been online......... Allthehomo.jpg :woot:
Both bloody whores!
Well Chris book your car in and I can take it to the mechanic for ya when I pick up my trophy?
Anyways give me a bell if you need
ill try have the tyre off tomorrow night, see if i can get mum to get it sorted while im stuck at work on light duties haha
Both bloody whores!
You love us :3some:
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
