Hi sorry to have one of my first posts as a help me one!
I have a series one stagea with, fmic, full exhaust (turbo back) induction kit, and the free boost mod well thast all the engine mods. I had hesitation thru the revs so fitted new uprated coil packs and sparks but now when gunning it it gets to 4.8k and coughs , in a kinda cut out way, for a second then carries on pullng like a train.
any ideas?
cheers!
oh and some stagea pics for you.
https://www.sau.com.au/forums/topic/412499-stagea-cough-at-48k/
I'm guessing you've wound up the boost on a standard computer? Anything above stock and you COULD start seeing issues. Particularly if you have a free flowing exhaust and intercooler.
Most people can usually get away with 10 to 11 psi which is all that is safe on the standard turbo anyway.
yeah another vote for edge of the tune
there is a thread in the forced induction section about this
its the ecu going into R&R around peak torque
some form of tune will fix it but its an annoying proposition for a s1 stagea
emanange is probably the best to go for
A nistune won't work. You will need to get something with a R34 type plug. There is also the issue of Nissan using 3 different ECUs on the series one. There is only ever one wiring diagram in all the manuals so you may have to trace everything yourself.
  • 5 weeks later...
My NM35 is doing the same thing - no idea on previous tuning history though, what are my best options for tuning?
Fix the problem before thinking about tuning.
Check all intake/cooler pipe clamps, clean afm, change plugs, check for cracked or perished hoses etc.
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
