Hi Guy's
My R32 GTR is up for sale, don't really get to drive it any more so it's up for grabs. has a long list of mods and never been to the track or drags Been fully respayed about a year ago. Bought the car off a forum member PhilGTR who did the engine rebuild. Had all the recipts but can't find them at the moment. But will keep looking for them .It has a fully forged re built engine Mods are as follows.Also comes with a set of standard r32 GTR wheels. Bargain at this price. Please note the price is non negotiable, Will not drop the price at all.Very Very quick car. call me to ask any question 0411 574 412.
ACL Forged Pistons
ACL Piston Rings
ACL Big End Bearings
ACL Main Bearings
Ported and polished head
Stock polished crank and rods
Bored and honed Block
N1 Oil pump
N1 Water pump
Tomei Oil Gallery restrictor
Gates timing belt
New engine gaskets all round
New Thermostat
New NGK spark plugs
R34 GTR injectors
GT 28/60 - 7 Turbos
New Rod bolts, welsh plugs
Fresh paint on rocker covers
3" Trust Front pipe and Power Extreme II Cat back Exhaust
3" Metal cat
Twin Apexi Pods
Apexi Power FC & Hand Controller
Greddy Profec B Spec II boost controller
Nismo fuel pump
17" deep dish rims
adjustable cam gears
SARD 600 cc injectors
Splitfire coilpacks
Jim Berry clutch rated to 400kw
im sure there are a couple of others i have forgotten. Car is making 322rwkw and just needs a set of cams to really open her up.
Cheers Guys,
https://www.sau.com.au/forums/topic/412509-r32-gtr-for-sale-14000-sydney/
how much rego left mate? also what year model? does the AC work? any problems at all? im interested just waiting on my motorbike to sell (hopefully this weekend coming) thanks :)
Edited by barnoon
Hi Mate,
It has 11 Months REGO and is a 1990 model, the body is perfect. The only problem with the car is a slight oil leak from the oil return line from the front turbo, easy fix, just change the oil return hose. Also 4WD has been disengaged so only rear wheel drive :yes:. 322 KW at the rear wheels means allot of fun.
Price Drop to 13K but has to be gone by the weekend. Really need the cash.
Guys oil leak is fixed, Took the car to Matt at F&E he said that the 4WD issues seems to be the TPS as the pump is working very lazy. So that's a $400 fix guys, other than that the car is Great. 13K is a bargain!!!
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
