hey guys
selling off my project car r33 gtr i only really just bought it but have moved onto something else now and cant afford two projects
the shell will be up for sale soon, have to finish a few things on it first
the other parts are up for grabs now though
ALL PARTS LOCATED IN MACKAY NTH QLD, POSTAGE CAN BE ARRANGED
r33 gtr gearbox, recently rebuilt with new bearings.. has not been run since - $850
r33 gtr/gtst fuel tank, no pump - $100
r33 gtr nismo in-tank pump - $250
r33 gtr BC External Reservior coils, as new only fitted and moved 50metres - $1350
r33 gtr black oem front bar, good condition paint is scratched a bit - $500
r33 gtr/gtst greddy front strut brace - $125
r33 gtr/gtst oem rear brace, have two of these for sale - $100ea
r33 gtr carbon fibre grill with no symbol just mesh - $100
r33 gtr rear wing, carbon end caps - $350
r33 gtr front lights very good condition - $350
r33 gtr/gtst cusco hicas lockout bars very good condition - $250
r33 gtr cusco front swaybar - $250
r33 gtr moonface racing castor arms - $200
r33 gtr passenger seat, good condition - $150
2jz bottom end - freshly machined by jhh in brisbane
Manley turbo tuff i beam rods
Mahle race pistons 86.5mm
Arp l19 headstuds
Arp maninstuds
Acl race bearings
Machined/linished crank
Torque plate honed block
Gapped rings
Pistons, rods and crank balanced
just need to clean, check all bearing clearances and assemble - $5000
Random parts
AME TM-02 wheels, 18x10+15 all corners on 1000km old achillies 123s semis 265x35x18 - all very good condition no gutter rash - $2300
power enterprise 800cc top feed injectors 11mm x 6 in boxes with plugs, new - $600
genuine greddy type rs blow off valve vgc - $100
rochester 14mm 1200cc injectors x 4, never been used only fitted - $400
buddy club fixed back seat, has rail to suit s13/4/5. black with grey inserts for a normal sized person, has a small tear in the fabric other than that its as new - $450
sr20vet mazworx lhd intake manifold, no fuel rail as new condition just needs a throttle cable bracket welded on - $500
sr20vet steam pipe high mount t51r exhaust manifold as new - $200
s14 jic front strut brace, vgc - $125
s13 whiteline front swaybar good condition - $125
S14/15 K.L.S camber arms - $85
2jz exhaust manifold 3d flange ready to make a manifold - $100
thats it for now..
please contact me on 0413347774 or via pm
I live in mackay too mate, love those wheels just not sure how they'd sit on my R34, it's got pumped an flared guards, and 9" on the front is fine currently.
What's the chances of test fitting?
My car is out of action currently though.
Shell is now for sale... It wont be available for the next two weeks as im still in Brisbane
Info:
Front windscreen cracked
Steering coloum shaft will need to be replaced
Stripped interior, not one bit of wiring harness front to rear
Front guards modified as per picture
Custom dash reo bar made
Custom alloy dash made
Sound deadening partially removed - just the stuff i could get with dry ice.. Some still baked on like around the gbox tunnel
Front radiator support cut out - was planning on welding a couple tabs to it then bolting it back on via the tabs
Lower front chassis brace cut out and replaced with a piece of tube to give the radiator more room and be able to have the intercoler sit upside down and have its inlet and outlet very close to the intake mani and turbo for short piping.
Thats about all i can think of at this stage
It is a registerable car
The price will vary depending what you would want to come with it, in its base form:
No driveline just suspension arms minus the cusco hicas arms and swaybars
No wheels
No suspension
No frontbar
No lip
No wing
$1500
If you want it to come with other parts let me know via pm or phone call and we will sort out a price
I dont really know how to send a shell interstate so im going to go ahead and say qld buyers only
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
