Hey guys,
My partner hit her V36 while she was parking (pressed accelerator instead of brakes). We got in touch with two nearby repair shops who gave us the attached quotes and said similar things like heating up the bumper to fix it and then repainting it. Also, one of the grills broke but it's not that obvious so they said it would be up to us if we want to fix it or no. If anyone knows a good repair shop in Sydney (we live near Chatswood) then please let me know!! She does not have comprehensive cover at the moment.
Also, I wanted to ask what tyre pressure's usually recommended for 2008 V36 Skylines? We have got Dunlop tyres (245/45ZR18) on which it says max pressure should be 35 but on the car itself there's a sticker which recommends 34 for R19's. When we checked the pressure the other day it was 38 (we have had it for about 3 months now) and my partner panicked and brought it down to 32.
Any reply/advice would hugely appreciated. Thanks so much!
Edited by protik
https://www.sau.com.au/forums/topic/412556-urgent-v36-smash-repairs-in-sydney/
$30,000+ car and no comprehensive insurance???
On a more constructive note, I run 32 psi on my 19's at all times. If she tested them after driving around for a while then its possible that they went up to 38 from 35. Way to high in my opinion though. Always check the tyre pressure when the tyres are cold.
Bump!
Would appreciate any decent repair shop recommendations in Sydney guys :(
Also, does front and rear tyres need to have same or different pressure? I just spoke to the compliance workshop that sold me the tyres and the guy is saying that I should put it back to 38 psi (although it's written max 35 psi on the tyres itself).
Really confused..
Edited by protik
I recommend my beater whom I've dealt with since the old man had the Maxima. Cullens Smash Repairs in Auburn - 9748 1820.
Top job and as for price, no idea since I have comprehensive insurance. I strongly recommend you pull your finger out and get yourself comprehensive insurance too. You never know when you might hit that Ferrari one day or if some uninsured twat hits your prized possession.
I run 38psi all day everyday on my 19s and 18s. Pretty sure you are reading it wrong on your tire. Its probably saying don't inflate more than 35psi when mounting the tire on the wheel.
How did your partner manage to damage the front and rear when accidentally pressing the accelerator instead of the brakes?
Those quotes look fairly reasonable if its for front and rear repairs.
No woman should be driving an expensive car without comprehensive.
Anyways, prices you have been provided look reasonable considering a brand new bumper is $800 ex. and a 2 months wait. If you are willing to spend some money maybe upgrade to the sports bumper.
My 19's run at 36psi probably should run it slightly higher, I'd say for 18's like yours maybe 34-36psi.
Cullens Smash repairs deal with prestige cars so they should be good as recommended by Max.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
