i think merli said it before...but is there any point to gutting a cat for 3 or 5 extra Kw's? over the cost of health and the environment ??????
3inch from turbo to high flow cat, 31/4 cat back. Lag shouldn't be a problem.
If you think you can get away without putting one on (or want to chance it) then why pay $$$$ for one.(though i dont see the point in it to get one only to gut)
Aslo if your the type to worry about the environment then dont drive or even sell the car and buy a push bike.
Ash.
Ash.
So everyone that owns a car and doesn't care about the environment should have no cat then? I feel that we should at least try and prevent as much environmental damage as we can, and if that means using a cat, then we should do it. Choosing to run without a cat for a few kws is just not right in my eyes.
Originally posted by KamikazeR33
a high flow cat should give u the same power as a gutted one or none at all
i was using a straight through pipe for a bit on the '33, when i got a 4" high flow cat i didn't notice any difference in power output.... and people driving behind me weren't passing out. :) :)
I tried to post this at TAFE, but the computer screwed up. And a few people have already posted...
BUT. What I wanted to write at the time...
I think the attitude really really sucks on this. I wouldn't count me as a Greenie at all.
The removal of a cat is just plain stupid, and isn't going to be doing any of us any favours. The modified car scene is already tainted as it is without giving the local powers that be another reason to crack down on us.....All for a few kilowatts of power which I bet you couldn't even notice.
The cat, sa far as I understand, is there in an effort to change the raw exhaust gas to something which is alittle less harsh and can fliter back into the air as cleanly as possible. Tell me, how offen have you been pissed off with a car in front spewing rotten gas onto you and your car ? Why join them.....
If your off to the racetrack, yeah sure fit the pipe to bypass the cat...But for street use, when the car is going to burn most of its fuel.....I can't see a cuase for not having a cat....geezz you can even get high flow cats!!!
........That was my ramble..
NO CAT=DUMB.
ANDREW
It's one thing to go on about the stupidity of running without a catalytic converter, but how often does the average Joe check or replace a tired cat'?
Under ADR 37-00 your cat' is required to last 80,000km or 5yrs, whichever occurs first! How many cars on the roads in OZ would've had a cat' (or cat's) changed in their lifetime? Unless it’s totally stuffed & the honeycomb has collapsed into small bits you’d probably never know it wasn’t doing its job, unless the smell becomes MORE noticeable.
It’s my guess that apart from the performance automotive market & the EPA nobody else really thinks a hoot about the condition of their cat'!
An ineffective or blocked/damaged cat' is about as good as no cat' at all, worse in fact, 'cause it's not doing much for the environment OR the engine!.
My 2.2c
Note: NZ’ers aren’t legally required to run a cat’, so watch out on the East Coast when the wind’s really strong from that direction :)
You're right on the money there mate... Any car with more than 5 years on the clock is more than likely going to have a cat that isn't very effective at blocking all the noxious gasses coming out the back of their cars...
How many people do you know that actually change em? My last car was a camira with 200,000kms on it, still running the original cat! Tell me that wouldn't have been stuffed!
matt
My 2.2c
Andrew: YOUR A DIRTY GREENY! ;)
Have u seen the internal matrix of a cat? In essence it makes the exhaust gas cover a surface area of a football field! That can't be helping performance!
To protect the environment form all the non-cat people of the world i shall smoke one less cigarette a day!
werd, peace, respekt, out!,
Cheers,
Captain Planet!
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
