Max Amps Pulled From Battery / Cable Gauge Required To Relocate Battery To Boot
I searched for a DIY guide on relocating the battery to the boot, and surprisingly couldn't find anything!
Can anyone advise on the minimum cable gauge required to relocate the battery to the boot? I have a heap of 8AWG cable (61Amp capable) which I realise is probably not going to be sufficient, but I am just wondering if I run 2 of the lines if it will be enough?
Cheers :cheers:
Justin
depending on the quality of the cable i recommend 2awg as a minimum preferably larger,
i measure a starter on a v6 commodore 160amps on cranking. which has lower compression so i assume less work would be needed to crank.
Cheer's for the responses :no: Looks like even 2 x my 8AWG wire is not going to cut it!!!
I think I will leave the battery relocation for another time.
2ga is more than plenty, it is also the same as the -ve line from a mig welder. Hit up BOC gas and just buy some welding cables, works out cheaper than 2ga audio cable :)
My Gtr had the battery relocated to boot, used 2gauge cable, never have a problem with voltage drop or any other electrical problems (apparently these cars are voltage sensitive)
6 Cyl Starter motors usually draw between 200-400 amps. No amplifier wire is going to cut it. You need minimum 2 gauge battery/starter cable. It's about $10/m at repco from memory
welding cable works out a tad cheaper if you have a trade account :)
Also don't forget your starter motor will draw more current in winter and also when the battery is lower in voltage. You need to account for these factors so you don't catch things on fire. Safety first :)
I used 0 gauge audio cable. And I ran both earth and positive. I didn't want to earth though the body. U can't go wrong with over earthing.
Cost alil bit, but I hate wiring probs so I just over killed it so there won't b issues.
  • 4 weeks later...
What are people using for distribution blocks once they have relocated the battery? Having a bit of a look at options for such things at the moment.
stereo components really.. you just need a good ANL fuse & holder that that's it.. don't waste your time with anything else :)
Custom made...
Neutral bar with stand offs in a jiffy box.
    • That is the option code, not the VIN
    • Apologies if I sounded like a arse My point was that you will not be able to buy a rotisserie that suits your car, you get the rotisserie frame, and then fabricate parts to mount the rotisserie frame to the body The rotisserie side is easy, but the fabrication of the actual mounts is the tricky part, where to mount so you don't bend/twist the body, plus the geometry involved to get it to turn  If your capable at fabrication, and can work out where the C/L is in relation to the weight is so it actually can turn, you should be sweet I would love to see the progress on this just for the thought processes and fabrication
    • Type "M2" means it's a series 2. I would not be shocked to learn that the production changeover was somewhat lax and a late 12/95 production car actually got mostly series 2 parts with a bit of series 1 leftover. Post the VIN and it'll be easier to investigate.
    • Yes, well, mine were 31 years old last year when they finally got done. Started to leak a bit.
