Hey all,
Im looking at putting an oil cooler on my r34 and was wondering is there any preference, brands, thermostat or not etc?
The car is hoping to see a few track days nothing to major.
Cheers,
James
Group buys
Autobahn 88 ebay
Mocal
Setrab
Earls mounted right
Hks
Greddy
thermostat preferred , nessasary if you live anywhere coldish in winter
Noticed the autobahn fittings are the same as a few other brands
you will need a stainless braided hose cutting item, grinder with diamond blade makes clean quick cuts , airsaw
Most likely angled fittings , i just did mine and had to get some angles to make it neat
You will need strong zip ties
Alloy or rubber coated P clips and a few parralel alloy blocks to make it nice , a length of rubber or protective material about a half metre long
stainless is like a slow chainsaw on metal frames etc
Remote filter bolts right on fuel filter braket hose , move the filter back a bit
The filter supplied by some companies is off a honda . But can be substituted easy
pirtek has bits but not cheap " proflow"
You will need some metal strap or strap iron /alloy that you can bend , paint, drill and mount
You will also need some bolts unless you have a fmic that works perfect to piggy back that mount bolt
Mount the cooler up not down to avoid air traps
it fit fine in front of washer bottle
Edited by Carbon 34
https://www.sau.com.au/forums/topic/412608-oil-cooler/#findComment-6600381
If you want less headache and straight bolt up affair, look at the GReddy GREX Oil Cooler kits. They can be had for under $900 from eBay or forum traders, everything is plug and play and has a built in thermostat in the sandwich plate.
https://www.sau.com.au/forums/topic/412608-oil-cooler/#findComment-6601333
Unless its made exactly for the model it takes about the same amount of work ? Not many kit are plug and play simple unless you pay dearly for it
Most of the work is laying it out and plotting the path , the install tutorial here wasnt up to my standards but was helpful insight into mounting ideas
Anyway you can get the setrab type setup for a third of that cost !!
https://www.sau.com.au/forums/topic/412608-oil-cooler/#findComment-6601686
http://www.rhdjapan.com/hks-oil-cooler-kit-type-s-nissan-skyline-ecr33-er34-50514
Plug and Play, no headache like I said.
https://www.sau.com.au/forums/topic/412608-oil-cooler/#findComment-6601716
This should cover everything. Good price too.
What I'd recommend, remove the stock oil heater/cooler and replace with a oil filter stud to allow the oil filter to screw straight to the block. Perfect for relocation kits!
Here's how I did mine; (haven't plumbed in oil cooler yet).
https://www.sau.com.au/forums/topic/412608-oil-cooler/#findComment-6601831
This is what I went with:
http://www.helcarkits.co.uk/index.php?main_page=product_info&cPath=205&products_id=957
Supposed to be here on friday so will see how it looks. But has all the right stuff - thermostat, braided lines, all fittings and 19 row cooler
$460AUD delivered I think it was so pretty good price
https://www.sau.com.au/forums/topic/412608-oil-cooler/#findComment-6601840
fitting these oil cooler does it remove the oil water heater or whatever they are called?
It can , depends on how its hooked up?
if you ditch the housing for rb20 its no longer needed
If you dont its your choice ?
https://www.sau.com.au/forums/topic/412608-oil-cooler/#findComment-6601957
Still missing remote filter and another hose ? 745 bucks
anyway I haven't installed that brand so cant comment on how fiddly it is
You wont find purple fittings easy I would think? If that matters ?
Edited by Carbon 34
https://www.sau.com.au/forums/topic/412608-oil-cooler/#findComment-6601965
I fitted one to a R33 years ago, pretty straight forward. No headache with making brackets or guessing how much hose you need. A mate paid like $500 or so delivered from Yahoo auctions.
Depends if you need a relocator or not, changing oil filters on RB20/25s (with stock plenum) aren't as bad as RB26s, which is a pain in the arse
https://www.sau.com.au/forums/topic/412608-oil-cooler/#findComment-6602630
I had a problem with the Autobahn 88 filter relocator, the guys a the filter factory helped me out.
The rb 20 (dunno about rb25) does not use a filter with a bypass, as the bypass is in the motor, and the thread supplied with the kit was metric, no non bypass filters with a metric thread.
So i had to get a new remote filter head as the thread in the auto88 one could not be changed easily.
Mine was not a direct fit and i had to put the battery in the boot to get some room.
Extra money and time to custom make one to fit, it can be a real pain. Cheap to buy initially but not cheap to fit.
A direct fit would be real nice.
Ps: dont forget the oil thermostat!
Edited by D.I.Y. Mik
https://www.sau.com.au/forums/topic/412608-oil-cooler/#findComment-6607452
I just fitted a Mishimoto kit to my 34gtt
Brilliant little kit and everything fit straight out of the box. Retained the stock cooler as well. Wasn't much point in removing it. And decided not to go for a thermostatic sandwich plate. It warms up fast enough on its own.
$400 delivered from frsport.com
https://www.sau.com.au/forums/topic/412608-oil-cooler/#findComment-6614789
Without a thermostat in the winter in some locations the oil doesn't get hot enough to flow properly , bad on bearings in some cases or could cause oil starvation if the oil isnt synthetic and clags up
Normal mineral oil can freeze solid !! even at 0c its like mud or syrup
https://www.sau.com.au/forums/topic/412608-oil-cooler/#findComment-6615094
