update: just pulled the TV tuner out of my pc to get model numbers off the chipset, a quick google and i have found the BDA drivers and im a happy camper again
i have a 120gb Sata3 ssd Ryan and from power on to using windows is about 30secs including POST
SSDs are ruining the computer user experience.
I remember when I'd hit the power button, then have time to go and get a coffee before it had booted into the OS. Now my MacBook Pro with 128GB SSD boots in about 20-30s, and I don't have time.
Dad's new Win7 machine with 60GB Vertex SSD is about the same.
It bothers me.
  • Replies 48
Haha I'm hearing you, someone has already made a USB coffee warmer but what about one that boils the water first
Funnily enough, I have one of those mug warmers. Need a coffee machine I can control via the web/smart phone.
^^ awesome
i am sort of deciding whether or not to buy Start8 start bar, i know there are free ones but the free one i tried doesn't look as polished as start8
I'm pretty sure there is a registry tweak that is surfacing. If I find it I'll let you know, might save the purpose ;)
Also for anyone that isn't partial to Metro being your start up screen, use this - Skip Metro Suite
Few little tweaks with that app that might prove useful for some.
I'm keen in this http://m.samsung.com/au/consumer/pc-peripherals/notebook-pc/slate-pc/XE700T1C-A01AU
Spoke with Harvey Norman, they are only ordering the 128gb models, no idea on eta o stock, and $1800 :/
that above samsung is a tablet, docked its a laptop like all are - and running full windows. The costs is a kick in the nuts.
They are releasing the windows RT units first and holding back all full win8 units to get some sales for the RT.
So long as you don't use a media extender you should be right, I also read something with media browser doesn't work either due to not being able to mod the .dll file's my channel logos has an issue also due to .dll
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
