  • Replies 48
ahhh :whistling:
Asus Transformer Infinity - 64gb
http://eee.asus.com/...finity/features
So far super happy with it. Fast, lots of apps (tho Polaris is not an alternative to Word or Excel - and they aren't available in the android store (yet hopfully) basic formulas work ok but the graphs dont link well at all).
Widgets work quite well, all screens can be customised with widgets and app icons combined. Not that i'm going to, but it had standard functionality to load customised ROM's on (a ROM is a different.custom operating system i assume).
The dock is very handy - full keyboard with all the required shortcuts to navigate around. No need for a mouse being touch screen, only gadget i will but is a stylus at some point to use with intricate photoshop editting. Seems to play a good variety of video formats (avi, mp4 etc.) and music formats (mp4 and m4r?). Has true GPS, and 3 GPS navigation type apps re-loaded for some reason. One is a handy 'whats close by' app for finding restaurants/shops/etc. close by.
It has a camera - that is all. I'm not going to use the fkn thing and look like a cock head.
Super thin and light - will be alot easier to cart around on my upcoming holiday overseas than the massive heavy laptop (which never seemed that huge until now).
Downloaded the Photoshop Touch app yesterday - not had a chance to use it yet but it appears very powerful. Going to hunt down a RAW image app also. Both apps combined means i can use the tabelt whilst overseas to review and edit up photos taken :)
Edited by barraspalding
And its quad core, 1920x18080
Nice touch the bootloader being unlocked
Yeah roms contain all the files like a win xp, 7 8 disc would hold when you load your OS all custom roms are a little bit different
    • Not too sure just yet, want to have a go at doing what I can myself, but to start with want someone to cast their eye over it tell me what needs doing to get it running and back on the road, so anyone with great overall knowledge would be ideal.
    • I personally would go with cutting out the rubber. Then deal with getting sleeve off separately. Rubber can be painful to cut, it loves to jam up cutting tools. I normally have success with drill bits, deburr bits, angle grinders, jigsaw, reciprocating saw, and never forget... fire. Obviously different tools won't work in all locations you're trying to work with, and you need to be comfortable with each. You personally may be happy slowly slicing it out with a razor blade, if you are, go for it with one too! Feel free to wait for others to weigh in also on their thoughts.
    • So ... I got everything disconnected and started dropping the frame. Three of the four mounts started to come down but the fourth one (the one with the nut that gave me all the trouble) won't budge. The inner metal sleeve stays up tight against the chassis rail although the outer part of the mount drops a bit (and can be levered quite a lot more) but it's just stretching the rubber bushing. So I reckon there's some serious corrosion inside the inner sleeve and holding it tight to the lug at the top of the bolt. Tried everything I can think of so far: penetrating oil, whacking the top of the sleeve to vibrate it and wedge a screwdriver blade in there. I also tried to turn the inner sleeve a bit by hitting it with a chisel at the bottom. It's stuck solid. What do you think about cutting the rubber with a blade so I can drop the subframe around it anyway. Then worry about getting the inner sleeve off after? Will that work? Is it gonna give me even more problems?
    • Steam valve seals are usually responsible for cold start smoke, it goes away once engine warmed up. Disconnect it let engine breathers and let it breath freely, see if problem goes away after a short drive. Also check to make sure engine oil drain pipe is not blocked or kinked.
    • Haha thanks! Yea I'm moving over from 2x 1000cc jets pre throttle over to 6x 190cc direct port jets and 1x 500cc pre throttle jet.  Direct port comes with all the advantages you would expect, except that pre throttle does cool down IAT'S more. That's why my direct port nozzle placement is closest to the plenum as possible in the runners to allow the air more time to cool before being sucked in. I'm also putting that one 500cc pre throttle jet to help with more cooling. It's a hybrid system. There's a lot more advantages to moving over to a PWM solenoid with a constant pressure system vs my old PWM pump setup, but I'll get more into that once I'm done converting everything over. The ricer in me is excited to see SS tubing all over my manifold though!
