Hey all getting a few sets of rims now lol and moving out soon so i need to de clutter and get rid of them.
I curently have the drifteks on my car but not sure if wanna keep them or the starcorps. Depends what intrest i get is most likely what i keep.
So got a set of 18x8.5 +34 and 18x9.5 +35 Gold/bronze drifteks. Tyres are good nic as the rims as in pretty good condition. They have 225 all round (yes a little strech i didnt do this) Front 60-70% as the rears are the same or a little more. Looking for around the 1100 area, im pretty easy going so dont be scared to offer BUT nothing stupid.
Also got a set of starcorp impuls i think is the way, work equip copies. Good condition, minimal gutter rash on these. Tyres on the front are 225 with maybe 30% left and the rear are 235 with a good 80% , they still have the nibs on outside. Wheel specs are 18x8.5 +35 (not 100% they might be 38) and 18x9.5 +38. Price is around the 650 mark.
Last of the rims are a set of Volk Av3, Here is the link to the info / my other add. Still want 300, thats fairly firm
http://www.skylinesaustralia.com/forums/topic/402316-wts-rims-volk-racing-av3-melbourne/page__fromsearch__1
Also have a set of R34 gtt bonnet hinges, 50 buck ono
Located in Melbourne, Can pm me for more info or send a text on 0433659311
Cheers damien
Starcorps
Drifteks
Anymore pics i can mms or take at request :)
Volk are sold
Starcorp are sold pending payment pick up
No interested in drifteks, only way not is swaps and cash either way.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
