hey guys
im in the works of planning a 25/34 build to go into my 34 GTT, im sourcing parts prices etc but one thing that im questioning is the neo head. Ive built a 25/30 for my 32 using a 33 series 2 head which i got the water gallery welded, and a external oil feed for the lifters is the neo head requiring the same work? im sure the water gallery has to be welded but is there anything different between a neo head opposed to the 33 head that needs to be addressed for this conversion??
thanks
https://www.sau.com.au/forums/topic/412621-rb2534/
would it be worth using a 33 series 2 head? i assume the majority of the 34 wiring harness is the same as the 33?
i had a 25/30 in my 32 originally had a 25 in it, and when i got it tuned the tuners said it had a 34 wiring harness
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6602374
34 head is far better, just allow for the 34 when choosing pistons etc.
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6602518
what do you mean by allow for the 34?
What Jonathon said - the Neo head has a smaller combustion chamber than the R33 so you need to take that into account when calculating your compression ratio. Should be fine with the extra capacity of the 3.4 block - Neo is the superior head. Look forward to seeing the result!
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6603125
The lifters will be fine. Just use the correct oil restrictors. We converted our r33 s2 head to solids and I made two 1.1mm restrictors using m8 grub screws. Has worked fine so far. This is on a spool rb34 stroker also.
As they said already you just need to cc your chambers and get the pistons to suit so your compression doesnt go sky high. Otherwise no worries!
Be prepared for a nice fat torque and power curve. From our old rb30 our whole power curve moved to the left by a good 1000rpm and we picked up something like 160hp more through the midrange. Makes the car so much nicer to drive.
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6607090
what is the approximate additional cost in block prep to fit the 34 crank in? the spool site mentions there is some minor modifications required to make it fit.
i'm looking at a 26/34 conversion into my 32 GTR down the track (when i get the $$ for it) was weighing up a 2.8 stroker but leaning towards going all out with the 34 since im more looking at low end torque and dont want to wait till 4.5k rpm for boost.
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6608666
ahhh ok that makes sense im getting a spool kit for my build, out of curiosity what did you set your compression ratio at?
thinking of using a JUN pump
Mine is a bargain basement build with stock pistons resulting in about 8.2:1 CR :/
As yours will be fully forged etc something well north of 9:1 or even more if you are going to run E85 would be good!
I have an N1 pump but don't limiter bash and have 7000 max rpm.
Jun sounds good - Tomei may be better but people swear by Nitto pumps - no experience of them myself!!
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6608779
The pictures on their site show a small amount ground away for the extra clearance needed for the 3.4 - looks like a very small job - less than 15min labour.
Go the 34 - I want to see more results!!
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6608781
spool RB32 don't need any clearance and unlike the nitto RB32 stroker the spool on is a 3.2l
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6608872
So? The extra capacity of the 3.4 comes from a longer stroke. Longer stroke means a larger diameter crank, which naturally needs more room to spin around.... What's your point?
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6609218
was just saying some people don't like machining the block for Clearance as it weakness the block a bit Edited by MRHD66
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6609521
It will be interesting to see more results, I've only ever come across the spool s15 dyno graph. It's a good thing. Is there any other 3.4L results you guy know of?
I like the idea of the 3.4, considering its really the same cost as going 2.8 from a rb26, obviously exept the mods to fit an rb 30 in your car.
What rpm are you looking to turn this to?
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6611019
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
