hey guys
im in the works of planning a 25/34 build to go into my 34 GTT, im sourcing parts prices etc but one thing that im questioning is the neo head. Ive built a 25/30 for my 32 using a 33 series 2 head which i got the water gallery welded, and a external oil feed for the lifters is the neo head requiring the same work? im sure the water gallery has to be welded but is there anything different between a neo head opposed to the 33 head that needs to be addressed for this conversion??
thanks
https://www.sau.com.au/forums/topic/412621-rb2534/
would it be worth using a 33 series 2 head? i assume the majority of the 34 wiring harness is the same as the 33?
i had a 25/30 in my 32 originally had a 25 in it, and when i got it tuned the tuners said it had a 34 wiring harness
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6602374
34 head is far better, just allow for the 34 when choosing pistons etc.
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6602518
what do you mean by allow for the 34?
What Jonathon said - the Neo head has a smaller combustion chamber than the R33 so you need to take that into account when calculating your compression ratio. Should be fine with the extra capacity of the 3.4 block - Neo is the superior head. Look forward to seeing the result!
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6603125
The lifters will be fine. Just use the correct oil restrictors. We converted our r33 s2 head to solids and I made two 1.1mm restrictors using m8 grub screws. Has worked fine so far. This is on a spool rb34 stroker also.
As they said already you just need to cc your chambers and get the pistons to suit so your compression doesnt go sky high. Otherwise no worries!
Be prepared for a nice fat torque and power curve. From our old rb30 our whole power curve moved to the left by a good 1000rpm and we picked up something like 160hp more through the midrange. Makes the car so much nicer to drive.
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6607090
what is the approximate additional cost in block prep to fit the 34 crank in? the spool site mentions there is some minor modifications required to make it fit.
i'm looking at a 26/34 conversion into my 32 GTR down the track (when i get the $$ for it) was weighing up a 2.8 stroker but leaning towards going all out with the 34 since im more looking at low end torque and dont want to wait till 4.5k rpm for boost.
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6608666
ahhh ok that makes sense im getting a spool kit for my build, out of curiosity what did you set your compression ratio at?
thinking of using a JUN pump
Mine is a bargain basement build with stock pistons resulting in about 8.2:1 CR :/
As yours will be fully forged etc something well north of 9:1 or even more if you are going to run E85 would be good!
I have an N1 pump but don't limiter bash and have 7000 max rpm.
Jun sounds good - Tomei may be better but people swear by Nitto pumps - no experience of them myself!!
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6608779
The pictures on their site show a small amount ground away for the extra clearance needed for the 3.4 - looks like a very small job - less than 15min labour.
Go the 34 - I want to see more results!!
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6608781
spool RB32 don't need any clearance and unlike the nitto RB32 stroker the spool on is a 3.2l
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6608872
So? The extra capacity of the 3.4 comes from a longer stroke. Longer stroke means a larger diameter crank, which naturally needs more room to spin around.... What's your point?
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6609218
was just saying some people don't like machining the block for Clearance as it weakness the block a bit Edited by MRHD66
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6609521
It will be interesting to see more results, I've only ever come across the spool s15 dyno graph. It's a good thing. Is there any other 3.4L results you guy know of?
I like the idea of the 3.4, considering its really the same cost as going 2.8 from a rb26, obviously exept the mods to fit an rb 30 in your car.
What rpm are you looking to turn this to?
https://www.sau.com.au/forums/topic/412621-rb2534/#findComment-6611019
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
