I've read on the spool site 2 different stroke sizes for the RB34 so what is it 94mm or 95mm I'm confused
Maybe the earlier cranks were 95mm and the newer versions (full counterweight) are 94mm. Maybe to reduce the amount of clearancing required on the girdle.
https://www.sau.com.au/forums/topic/412621-rb2534/page/2/#findComment-6616453
That is correct. It was reduced to 94mm for clearancing issues. Alot of people were scared about having to take to their block with a die grinder to remove material.
cool as but now it should be called a RB33 as its closer to 3.3l then 3.4l
https://www.sau.com.au/forums/topic/412621-rb2534/page/2/#findComment-6618086
yep. I didn't think he still had the 95mm ones?
me either even tho that would be the one I'd really want did u use a standard cradle I'm thinking of using a spool cradle and main caps Edited by MRHD66
https://www.sau.com.au/forums/topic/412621-rb2534/page/2/#findComment-6618170
My one works out to be 3352.8cc. With a 87mm bore though.
Depends on bore size really.
Was gunna say, if it's 40thou over (3.46 bore x 3.70 stroke) = 208.74 ci which = 3,421.17 cc or 3.4 Lt
What power level are you chasing? I've read the standard caps and girdle are good for 1000 hp. I'm getting a rb34 short block from spool with the standard girdle. I'm chasing 800 ish
Edited by brenton21
https://www.sau.com.au/forums/topic/412621-rb2534/page/2/#findComment-6618226
sweet good to know
https://www.sau.com.au/forums/topic/412621-rb2534/page/2/#findComment-6618264
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
