  On 08/11/2012 at 4:39 AM, MRHD66 said:
I've read on the spool site 2 different stroke sizes for the RB34 so what is it 94mm or 95mm I'm confused
Maybe the earlier cranks were 95mm and the newer versions (full counterweight) are 94mm. Maybe to reduce the amount of clearancing required on the girdle.
https://www.sau.com.au/forums/topic/412621-rb2534/page/2/#findComment-6616453
  On 09/11/2012 at 10:08 AM, r33_racer said:
That is correct. It was reduced to 94mm for clearancing issues. Alot of people were scared about having to take to their block with a die grinder to remove material.
cool as but now it should be called a RB33 as its closer to 3.3l then 3.4l
https://www.sau.com.au/forums/topic/412621-rb2534/page/2/#findComment-6618086
  On 09/11/2012 at 11:04 AM, r33_racer said:
yep. I didn't think he still had the 95mm ones?
me either even tho that would be the one I'd really want did u use a standard cradle I'm thinking of using a spool cradle and main caps Edited by MRHD66
https://www.sau.com.au/forums/topic/412621-rb2534/page/2/#findComment-6618170
  On 09/11/2012 at 10:20 AM, r33_racer said:
My one works out to be 3352.8cc. With a 87mm bore though.
Depends on bore size really.
Was gunna say, if it's 40thou over (3.46 bore x 3.70 stroke) = 208.74 ci which = 3,421.17 cc or 3.4 Lt
What power level are you chasing? I've read the standard caps and girdle are good for 1000 hp. I'm getting a rb34 short block from spool with the standard girdle. I'm chasing 800 ish
Edited by brenton21
https://www.sau.com.au/forums/topic/412621-rb2534/page/2/#findComment-6618226
sweet good to know
https://www.sau.com.au/forums/topic/412621-rb2534/page/2/#findComment-6618264
My bad. Just realised l worked that out as a 88mm bore. not 87mm. sorry
https://www.sau.com.au/forums/topic/412621-rb2534/page/2/#findComment-6619628
