Easy to source, nice and cheap: what's not to like?
I have also been in regular contact with another Y34 owner who has successfully sourced (Maxima?) brake pads, and shimmed them to fit our cars: will post part numbers when I get them...
Also, just FYI: not sure if it's a common issue (I haven't experienced it), but he had ongoing, intermittent rough-running issues, which after much diagnosis turned out to be failing ignition coils.
Just a couple of things to bear in mind: once we get enough info, it may be a good idea to create a Y34 parts/service sticky thread, as there's precious little information available on the interwebs...
Yeah i agree - i've found there's really not much info available on there however Aus-Vip.com i have found has a little.. not much.. but a little haha. I have the same intermittent rough-running issues but i had put it down to coilpacks as it seems to be the same sort of issue as what I had years ago in an S13 then replaced the coilpacks and all fixed.
I havn't bothered to buy new coilpacks yet for my Y34 but was planning on getting a set of Yellow Jackets from performance-wise.
Also I had my radiator end tanks replaced which turned out to be the same/very similar to Navara radiator end tanks so they were used :)
And when i needed new brake pads I took the worn out pads to SA Brake & Clutch and they matched them up with some replacements - no modification was needed either.
yeah: the brake pad thing seemed a little odd to me: I figure I'll be able to source a set of Endless or similar quite easily. Will do some research to ascertain whether ours are the same as the USDM M45- I'd say it's a pretty safe bet. Also, have seen a number of Y34s going at auction with what I believe to be CPV35 Brembos fitted, so it may be that we run the same brakes as a non-brembo V35, given Mr. Nissan's tendency to use interchangeable parts.... Once again: more research required.
For anyone looking for more info on part compatibility for Y34's (servicing, etc) see this thread: http://aus-vip.com/topic/2778-y34-gloriacedric-maintenance-info-part-number-listing/
  • 1 month later...
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
