  • 1 month later...
does anyone know how to change the clock?
Good question! I've heard you have to take the dash out to do it.. but i dont know why.. or how you actually change the time.
Anyone else able to help??
  • 4 weeks later...
You can't change the clock it's set via the cars gps that's why it's always in japans time. Though I did find a menu today that I need to look for again.
It got me into a menu I have never seen before had gps, music and screen settings for contrast and brightness as well as gps correction etc... oh could I also have a copy so I can add stuff to it.
[email protected]
[email protected]
Hi,
Have just emailed you the Y34 english translation document for you.
Im interested to know about this extra menu you found? perhaps its the one shown in the english translation, or perhaps it's not??
Always nice to meet more Y34 owners :)
  • 3 weeks later...
Hi Guys If I could have a copy of the Y34 Owners manual in english please to e-mail [email protected] it would be much appreciated. My wife is getting cranky with the drivers window dropping down when she opens the door. Don't know why that woould be an option but it is!!
Haha yep! that's a function you can alter from memory.
I'll email now for you :)
  • 3 weeks later...
  • 3 weeks later...
I would really appreciate the English manual too please send to [email protected]
If I can add anything to help I will, my Cedric is currently on a slow boat from Japan.
Thanks
Have emailed you :)
  • 4 weeks later...
  • 3 weeks later...
Hi there , i been trying too find owners manual and workshop manual for my car, its a 2001 Nissan Cedric HY34, Please could i have a copy ? Thanks [email protected] i also wanted to ask if the Aftermarket Nissan 350Z Exhaust Headers fit on the 3.0ltr Vq30 heads ??
Thanks
Thanks
Could I too get a copy of the english manual?
[email protected]
Hi would it be okay if you could send me a copy of the manual too. Thank you so much
[email protected]
ALL EMAILED! :)
  • 3 weeks later...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
