  • 1 month later...
does anyone know how to change the clock?
Good question! I've heard you have to take the dash out to do it.. but i dont know why.. or how you actually change the time.
Anyone else able to help??
  • 4 weeks later...
You can't change the clock it's set via the cars gps that's why it's always in japans time. Though I did find a menu today that I need to look for again.
It got me into a menu I have never seen before had gps, music and screen settings for contrast and brightness as well as gps correction etc... oh could I also have a copy so I can add stuff to it.
[email protected]
[email protected]
Hi,
Have just emailed you the Y34 english translation document for you.
Im interested to know about this extra menu you found? perhaps its the one shown in the english translation, or perhaps it's not??
Always nice to meet more Y34 owners :)
  • 3 weeks later...
Hi Guys If I could have a copy of the Y34 Owners manual in english please to e-mail [email protected] it would be much appreciated. My wife is getting cranky with the drivers window dropping down when she opens the door. Don't know why that woould be an option but it is!!
Haha yep! that's a function you can alter from memory.
I'll email now for you :)
  • 3 weeks later...
  • 3 weeks later...
I would really appreciate the English manual too please send to [email protected]
If I can add anything to help I will, my Cedric is currently on a slow boat from Japan.
Thanks
Have emailed you :)
  • 4 weeks later...
  • 3 weeks later...
Hi there , i been trying too find owners manual and workshop manual for my car, its a 2001 Nissan Cedric HY34, Please could i have a copy ? Thanks [email protected] i also wanted to ask if the Aftermarket Nissan 350Z Exhaust Headers fit on the 3.0ltr Vq30 heads ??
Thanks
Thanks
Could I too get a copy of the english manual?
[email protected]
Hi would it be okay if you could send me a copy of the manual too. Thank you so much
[email protected]
ALL EMAILED! :)
  • 3 weeks later...
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
