  • 3 weeks later...
  • 4 months later...
  • 1 month later...
@BurtoN86 if you ever sell your Gloria, would be highly interested, very hard to find one in Adelaide unfortunately, look after the beaut! [emoji106]
There is a few adelaide members on zeitakuvip.com with Y34's, imports seem to be pretty popular over there. A few cimas around too, if you wanted a V8.
Just an update on this translation document, I've gotten my hands on a Nissan Japan manual for the radio and navigation system and a number of other booklets/brochures. Updating it isnt my biggest priority, so I may just scan the pages and upload them and people can use google translate once they find what they need. I'll post a link here once its all scanned.
  • Like 1
On 9/5/2016 at 10:03 PM, Boybetterknow said:
@BurtoN86 if you ever sell your Gloria, would be highly interested, very hard to find one in Adelaide unfortunately, look after the beaut! ?
Haha cheers! have you seen it locally or? Feel frree to PM if you like :)
  • 3 weeks later...
Hi all, i have recently bought y34 rb25det neo engined cedric and im in complete love with it, however i do have quite a big problem understanding display unit and apart from engine which is familiar i have little to none knowledge of servicing, part interchangeability, etc.
If anyone could be so kind and send me a translated manual or any other cedric related info it would be greatly appreciated!
My email is [email protected]
Thank you guys for keeping this thread alive, as it has been a one of very rare sites, who has any info on these underappreciated cars! :)
Cheers!
Hi again guys, i love my cedric howevee it has developed a fault and i hoped maybe you could point me in right direction....
Basically - radio and ac/heating unit does not work at all. Rear demister works and vol. Buttons on steering wheel works but rest of it is not responding to anything.
Any ideas guys???
Yes mate done that. No change though :(
Is there any fuse box diagram for cedric floating around ? I read that similar year nissan primeras has issue where radio and heater controls stop working and its to blame connecto m54 or fuse 10, however without diagrams that isjt much of the help lol
No change? Did you check continuity of the fuses or...?
The only other thing i can suggest is to google similar issues for Infiniti M45's. Its a more reliable source than assuming a common problem with primeras. the M45s run a Bose stereo but most of the interior wiring should be the same. Theres a factory service manual available for the M45 (i have the link bookmarked but dont have it right now) which could possibly help.
Right, kept on tinkering with radio unit and disconnected ribbon going to tape deck , and what do you now, suddenly am/fm/cd started working - but only through steering wheel controls... still no luck with getting any buttons on unit itself to respond. The biggest worry is about heater controls though, because at the minute they are at 18.5 Celsius and its freezing inside the car lol :))))
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
hi all, newbe to the forum and would also like a manual in english if its no too much hassle please, email [email protected], ime in bonnie scotland, thanks lads n lassie.s,:14_relaxed:
  • 4 weeks later...
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
