Hey guys
I got a pair of sway bars for the front and rear of my car of a mate who was wrecking his 34.
But they didnt come with the necessary links/bolts.
Just wanna know what i need to fit em on my gt? If someone could link me it'd be awesome!
Cheers guys.
https://www.sau.com.au/forums/topic/412653-sway-bar-clips/
just use your existing brackets & nuts and buy the correct bushing, look for SuperPro bushing etc..
Sorry bud, i'm a noob with this stuff!
So the sway bar's just bolt in?
and are these the bushes:
http://www.ebay.com.au/itm/Nissan-Skyline-R34-Sway-Bar-link-Bushes-Kit-/290373828407?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item439ba0ff37#ht_2791wt_919
https://www.sau.com.au/forums/topic/412653-sway-bar-clips/#findComment-6601410
If it is aftermarket, you will need the correct 'D' shape bush to mount the anti roll bar up to the chasis of the car... with the end links, just use the stock ones.
it looks like:
Alrighty thanks for the info!
https://www.sau.com.au/forums/topic/412653-sway-bar-clips/#findComment-6601539
With my GTT swaybars the fronts use the standard links but the rears require aftermarket ones as they are a different design..... Depends if the bars you have are just thicker replacements or blade adjustable type?
https://www.sau.com.au/forums/topic/412653-sway-bar-clips/#findComment-6601559
Oh that sounds good, cos my rears have the links, but on the fronts they're missing.
Here's a picture:
https://www.sau.com.au/forums/topic/412653-sway-bar-clips/#findComment-6601785
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
