hey all, recentley picked up a auto r34 gtt 4 door and im not sure what boost it should be running
mods are
t04e stage 3 turbo
external wastegate
3 1/2 straight thru exhaust turbo back to a nur spec cannon
greddy fmic
spitfire coils
tomei fpr 90 psi
100 oct premium
its running 14 psi at the moment as is is that too much or can it go more every where i have looked has suggested 14 on a stock turbo is the limit but is that the limit for the turbo or the tune
thankyou
Standard ECU?
That will be your issue, I'm suprised you managed to run 14psi through a bigger turbo on the stock ECU and it works.
I dont understand what a T04e stage 3 turbo is...... has it been worked to flow more?
Either way a T04 is much bigger then stock so I would probably stick it on a dyno to check AFR's or wind the boost down to be safe
or get an aftermarket ECU and push it
well ive had it up to 17 - 18 psi before by accident and was surprised that i never hit fuel cut im pretty sure it is a stock engine and ecu apart from them mods turbo specs are
Inlet Diameter: 4"
Outlet Diameter: 3"
Compressor Wheel: .57 Trim
A/R Compressor: .50 A/R
A/R Turbine: .63 A/R
forged compressor wheel
what boost do you suggest for the time being as the nearest dyno is atleast 500k
if you bought the car and it was running 14psi and you cant hear any detonation etc then I guess it will be O.K
I wouldnt wind the boost up put it that way. Remove the passenger kick panel and see if it has an aftermarket ECU or piggyback. Sounds like it must have something to be able to hit those boost levels.
See what you can find
The whole combination of mods sounds weird, maybe the previous owner is telling fibs?
What boost guage are you running and where is it readig its pressure from?
What boost control method?
Its either not not a std ecu or its not hitting those boost levels or its a time bomb...
blitz dual ebc
reading boost from the stock sender
not sure where the turbo is from i was told it is a t3/t4 t04e stage 3 from the owner it doesent look like a ebay special but it could be fpr was set when i got it havent played with it what should that be set on?
had a mate come look at it this morning he does alot with silvias he adjusted the fpr for me its at 55 now
apparentley it has a mine ecu i think he said but he also said that 14 psi on the bigger turbo will be maxing out my injectors
then he said that he didnt think they made a mine ecu compatiable with tiptronic auto
FPR would have been set so high to allow the stock injectors to keep up... Bad idea to turn it down from where it was set. Though it is also a bad idea to keep running it as is regardless.
a genuine 57 trim will flow in the region of 400 to 450 hp
buy some genuine 600cc+ injectors
throw away your fpr (or set it back to 1:1 rising rate)
get a decent fuel pump
get a standalone ecu
put it on the dyno and tune until you start seeing your intake temps blow out (turbo efficiency range exceeded) or you run into some sort of restriction
the auto box may cause you some issues ...
Turn the boost down and drive it gently till its fixed or you could be looking at a new engine.
Take the car to a tuner and get him to have a look at the Mines ecu to see if its tunable (most are not).
If not buy a stock R34 auto ecu and get a Nistune chip put in it. Get some Neo friendly injectors 550 or better.
Look in the tank and see if you have a new fuel pump. If not, buy one and install it if you can or if not add it to the injectors.
You will need a genuine Z32 afm (and plug) if you haven't already got one.
Ask around and find a good tuner (in another town if necessary) and hand him all the bits (or install the bits and tow the car to the tuner) and get it tuned (point out, although he should notice, that the FPR needs adjusting). If nothing has been damaged it should go well.
In the meantime baby the car - no mega boosting, no skids etc.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
