hey all, recentley picked up a auto r34 gtt 4 door and im not sure what boost it should be running
mods are
t04e stage 3 turbo
external wastegate
3 1/2 straight thru exhaust turbo back to a nur spec cannon
greddy fmic
spitfire coils
tomei fpr 90 psi
100 oct premium
its running 14 psi at the moment as is is that too much or can it go more every where i have looked has suggested 14 on a stock turbo is the limit but is that the limit for the turbo or the tune
thankyou
Standard ECU?
That will be your issue, I'm suprised you managed to run 14psi through a bigger turbo on the stock ECU and it works.
I dont understand what a T04e stage 3 turbo is...... has it been worked to flow more?
Either way a T04 is much bigger then stock so I would probably stick it on a dyno to check AFR's or wind the boost down to be safe
or get an aftermarket ECU and push it
well ive had it up to 17 - 18 psi before by accident and was surprised that i never hit fuel cut im pretty sure it is a stock engine and ecu apart from them mods turbo specs are
Inlet Diameter: 4"
Outlet Diameter: 3"
Compressor Wheel: .57 Trim
A/R Compressor: .50 A/R
A/R Turbine: .63 A/R
forged compressor wheel
what boost do you suggest for the time being as the nearest dyno is atleast 500k
if you bought the car and it was running 14psi and you cant hear any detonation etc then I guess it will be O.K
I wouldnt wind the boost up put it that way. Remove the passenger kick panel and see if it has an aftermarket ECU or piggyback. Sounds like it must have something to be able to hit those boost levels.
See what you can find
The whole combination of mods sounds weird, maybe the previous owner is telling fibs?
What boost guage are you running and where is it readig its pressure from?
What boost control method?
Its either not not a std ecu or its not hitting those boost levels or its a time bomb...
blitz dual ebc
reading boost from the stock sender
not sure where the turbo is from i was told it is a t3/t4 t04e stage 3 from the owner it doesent look like a ebay special but it could be fpr was set when i got it havent played with it what should that be set on?
had a mate come look at it this morning he does alot with silvias he adjusted the fpr for me its at 55 now
apparentley it has a mine ecu i think he said but he also said that 14 psi on the bigger turbo will be maxing out my injectors
then he said that he didnt think they made a mine ecu compatiable with tiptronic auto
FPR would have been set so high to allow the stock injectors to keep up... Bad idea to turn it down from where it was set. Though it is also a bad idea to keep running it as is regardless.
a genuine 57 trim will flow in the region of 400 to 450 hp
buy some genuine 600cc+ injectors
throw away your fpr (or set it back to 1:1 rising rate)
get a decent fuel pump
get a standalone ecu
put it on the dyno and tune until you start seeing your intake temps blow out (turbo efficiency range exceeded) or you run into some sort of restriction
the auto box may cause you some issues ...
Turn the boost down and drive it gently till its fixed or you could be looking at a new engine.
Take the car to a tuner and get him to have a look at the Mines ecu to see if its tunable (most are not).
If not buy a stock R34 auto ecu and get a Nistune chip put in it. Get some Neo friendly injectors 550 or better.
Look in the tank and see if you have a new fuel pump. If not, buy one and install it if you can or if not add it to the injectors.
You will need a genuine Z32 afm (and plug) if you haven't already got one.
Ask around and find a good tuner (in another town if necessary) and hand him all the bits (or install the bits and tow the car to the tuner) and get it tuned (point out, although he should notice, that the FPR needs adjusting). If nothing has been damaged it should go well.
In the meantime baby the car - no mega boosting, no skids etc.
    • If you ask just me you'll get 3 different answers.
    • Do not ever trust ChatGPT with anything math related. They can't do math. They have no idea what it is. With enough data we can fit a decent equation in Excel, or if the available fits in Excel aren't good enough, a Matlab clone.
    • You could check/calibrate that with a thermometer, we have long glass thermometers at work which go from -10 to +150°c, they are pretty cheap too I believe,  as monkey fisted soldiers tend to break them, and getting new ones don't seem to send red flags to the people that hold the purse strings Edit: after a google they apparently cost about $80, but, digital ones seem to be much cheaper at around $40
    • I should have prefaced all of this with "I'd really like to not pull anything out of the car for this"
    • Me, I would happly spend some more coin on better tyres for my street car  Will they work, yes, of course, but why substitute some dry grip/braking distance, and wet weather grip/braking distance on what is really old tech to save some coin on your "precious" street car In the end it might not be you that farks up, it's the thousands of other idiots on the street that you need to worry about  For a street car that gets some "fun time", I have found that a quality tyre that can handle dry, wet, cold (Canberra gets pretty cold) and hot conditions, which may costs a little more, is great insurance  From my experience with them (driving around Goulburn in the winter) the RE003's are pretty poor in cold and/or wet conditions on the street If RS4's didn't hate gripping in the cold I would be running them always on the street,  great in the dry, OK in the wet, but, they do hate the cold, with a passion, I run PS5's year round now, basically, I've found the PS5 to be a great year round street tyre for all conditions, they last well, and are mid range pricing wise TL;DR. Tyre choice is probably like what brand and grade oil you should use, ask 10 people, and get 10 different answers... LOL
