Hello there,
I am looking for a replacement for the OEM rubber intake pipe since I suspect it sucks itself shut.
Are these silicone replacements any good or should I rather get a metal pipe (ApexI?)
Just an example:
http://www.ebay.co.uk/itm/NISSAN-SKYLINE-R33-RB25-TURBO-AIR-INTAKE-PIPE-SILICONE-/200454322924?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2eac023aec
http://www.ebay.co.uk/itm/SILICON-INTAKE-PIPE-4-SKYLINE-R33-GTST-R34-GTT-STAGEA-/160899111156?pt=AU_Car_Parts_Accessories&hash=item25765598f4
Thanks ..
https://www.sau.com.au/forums/topic/412779-silicon-intake-pipe/
I did this as well, but only in the upper third of the hose section.
I used a 100mm aluminium pipe but I suspect that the lower part
of the hose collapses.
I've used those silicon ones, they've collapsed on me running 1.3bar... proceeded with hacking up the stock one and putting in an alloy section in it... all good :)
Scotty - do you make these to order? :P
If so could you PM me with a price? :no:
I would need a 4" one for a low mounted GTX3071R, with the BOV return and catch can return inlets (I can supply these from the old pipe I have), going into a custom air box which I am yet to build. I am not running a MAF sensor so the pipe would go straight into the box.
So you want a 4 inch custom intake, made from 4000ks away with second hand bits? Sorry Justin, I can't work miracles. :P
BTW, I am making 350kw on a 3 inch pipe, why do you feel 4 inch is required? Or a custom airbox for that matter? The 80mm one above will do you fine. If you're running map sensored can't you just vent the bov?
Fair enough :P
I dont think the 4" pipe is a requirement, it just might be easier considering my turbo has a 4" inlet, and my airbox will be custom built. And I'm building the airbox for the challenge, I want to have a play with fibreglass and see what I can do (which could be a spectacular failure).
As for venting the BOV, I would rather recirculate if possible.
Hello there,
Just an example:
http://www.ebay.co.u...=item2eac023aec
http://www.ebay.co.u...=item25765598f4
Thanks ..
I haven't used one of the ebay pipes that you have listed but I have used SFS silicone intake pipes and they work fine. They have wire re-inforcement buit into the wall of the pipe so they don't suck shut.
With the poor exchange rate it might be worth you getting a custom pipe made up in the UK rather than importing an Apexi pipe in. A company near me does a lot of custom pipework but they might need to have the car to do it.
Cheers
Stu
Thanks Stu / all,
I'm really torn which route to go from here.
I am using the standard air-box with one of those green foam HKS panel filers.
(am considering using an ApexI panel filter)
Long background story ->
My boost drops from 1.2BAR to .75 starting at 4500rpm.
I talked to the turbo company (Turbo Technics) and they said the turbo (a hybrid) holds 1+ bar at 7000 rpm on a GTST.
My intake system (after the turbo) is fine so I suspect it is the hose or the air-box setup.
That's why I wanted to change the suction hose or possibly the air box.
I heard that the air-box is good for 300kw, but I doubt that the intake snorkel can accommodate 80% more airflow(?)
Option A is:
Silicone/metal suction pipe + ApexI panel filter
Option B:
Apexi suction kit
I like the standard air-box and am not sure about the benefits of a cone filter
Here's the ApexI kit:
http://www.partpal.c...n-print/view/36
My car makes 340HP at .75Bar (that's at the engine) and if I could get the boost back
it would be some horses more ;)
Cheers
Stu
Edited by Torques
  • 3 weeks later...
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
