Hey guys,
I've tried searching but couldnt really find much.
Currently making 347 rwkw
hks2540's i think - full boost of 22psi at around 5500 ish
powerfc
tomei adj gears
bosch 044
ported manifolds
hks dumps
hi-flow cat
z32 afms
sard 800's
Running standard internals
NOW to my question... How can i increase turbo response? Cams? What cams would be suitable Im hoping something along the lines of drop in i.e. keeping everything else stock.
I want a reliable driver also - and im 100% sure this car wont see a track day or drag strip plus i have shift light set at 7000rpms.
Lag is starting to annoy me and i really don't know what to do.. i cant afford to take out the turbos and buy and sell -9's or -5's.. What can i do to make the lag a little bit better/bearable?
Please don't flame, I'm asking a genuine question.
Thanks all
Edited by kinggtr
If you don't want to change your turbos then its just a matter of tuning to get as near as possible to the result you want. I would guess cams should stay stock but timing would need adjusting via the two adjustable gears (that's what they're for!)
Seems like you are in the same town as Status tuning so give them a ring and make an apointment - be prepared to spend around $1000 more or less for a decent tune.
I know you said you don't really want to change turbo's, but those 2540's are probably the worst lowmount setup on a GTR for any type of "'response". Cam timing and tunes are only gonna help so much.
A set of type R Poncams if you must buy a set of bumpsticks would be the go.
And make sure your exhaust doesn't have "step downs" that'll cause unnecessary back pressure
Turbos that size and an engine only revving to 7000rpm would be a dog to drive...
As already mentioned, well aware that you said a turbo change is not what you are wanting to look at doing - but at the end of the day the cams aren't going to be a budget mod and are really going to make so little difference you're going to wonder why you bothered imho, and will eventually have to do something drastic to polish the turd that is GT2540s (if you don't just replace them).
Honestly the most logical thing to do is change the turbos, as funnily enough anything else you do is not going to change that they are GT2540s and as such are going to behave like them.
Can I ask if you can't afford to spend the time removing the turbos or is it just a matter of money?
If it's just money i'm sure you can make a decent bit of cash back selling those and buying second hand -9s/-5s.
But yeah otherwise, who tuned the car and got a dyno graph of it currently? And have the adjustable cams been used to lower the power range?
Edit: What front pipes and cat back are you running?
Edited by Serpandrew
I'm not an RB26/GTR person but I'd look at it like this .
HKS effectively replaced the old "GT2540s" , which in todays speak are actually GT2876Rs , with turbos called GTRSs which are a GT2871R in 52 compressor trim .
People here say that it takes a specific combination of parts and good tuning to make GTRSs work on an RB26 and they actually use smaller but more modern compressor wheels than the old 2540s .
You could try all kinds of ways to work around those turbos but at the end of the day they are not a well though out turbocharger and you can do better .
Simply too big a compressor for the turbines to drive and thats what makes them lazy .
I think the designed for the purpose GT2859R (GTSS) are the go because they make boost and torque in the rev/speed range you can use in a street GTR .
Pretty sure you'd still make 300+ Kw but you'd drag the power range down possibly 1000 revs if not more .
So your call , either GTSS or inaptly called GT2530s I think .
A .
-9's are SS' s
-5' are close enough to 2530's.
Spend the money and rip those turbos off mate. You're about to drop a bomb of money and really, you're not gonna get the result you're after.
what are your cam gears dialled in as?
You could "possibly" get them to spool a tad earlier if you advanced the intake cams and retarded the exhaust cams a tad. A few people have gotten their GTS-ts to spool a tad earlier by retarding the exhaust cam gear only.
Hey guys
Firstly thanks for all your input on this matter - ill upload the tune soon.
Not to sure what's been improved from the cam gears other then an obvious lift on all parts on the graph.
I swapped out the gfb manual Bc and swapped it over for an eboost street and don't a few adjust I'm getting a rushing boost feeling from 3000 rpms and full boost at 4800 5000
Could they be 2530s? I also noticed an intercooler pipe leaking which I sorted out.
Lastly I spoke to my tuner and he explained how opts for a smooth graph and smooth power delivery. Maybe im just used to the standard response of the ceramic turbs?
Peak torque is 3/4 up the powerband, no wonder your not happy..
Im really with the others and will say spend wisely and just get real turbos. To match the peak you will need -5s. Check serial numbers before you do anything, obviously..
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
