Hey guys,
I've tried searching but couldnt really find much.
Currently making 347 rwkw
hks2540's i think - full boost of 22psi at around 5500 ish
powerfc
tomei adj gears
bosch 044
ported manifolds
hks dumps
hi-flow cat
z32 afms
sard 800's
Running standard internals
NOW to my question... How can i increase turbo response? Cams? What cams would be suitable Im hoping something along the lines of drop in i.e. keeping everything else stock.
I want a reliable driver also - and im 100% sure this car wont see a track day or drag strip plus i have shift light set at 7000rpms.
Lag is starting to annoy me and i really don't know what to do.. i cant afford to take out the turbos and buy and sell -9's or -5's.. What can i do to make the lag a little bit better/bearable?
Please don't flame, I'm asking a genuine question.
Thanks all
Edited by kinggtr
If you don't want to change your turbos then its just a matter of tuning to get as near as possible to the result you want. I would guess cams should stay stock but timing would need adjusting via the two adjustable gears (that's what they're for!)
Seems like you are in the same town as Status tuning so give them a ring and make an apointment - be prepared to spend around $1000 more or less for a decent tune.
I know you said you don't really want to change turbo's, but those 2540's are probably the worst lowmount setup on a GTR for any type of "'response". Cam timing and tunes are only gonna help so much.
A set of type R Poncams if you must buy a set of bumpsticks would be the go.
And make sure your exhaust doesn't have "step downs" that'll cause unnecessary back pressure
Turbos that size and an engine only revving to 7000rpm would be a dog to drive...
As already mentioned, well aware that you said a turbo change is not what you are wanting to look at doing - but at the end of the day the cams aren't going to be a budget mod and are really going to make so little difference you're going to wonder why you bothered imho, and will eventually have to do something drastic to polish the turd that is GT2540s (if you don't just replace them).
Honestly the most logical thing to do is change the turbos, as funnily enough anything else you do is not going to change that they are GT2540s and as such are going to behave like them.
Can I ask if you can't afford to spend the time removing the turbos or is it just a matter of money?
If it's just money i'm sure you can make a decent bit of cash back selling those and buying second hand -9s/-5s.
But yeah otherwise, who tuned the car and got a dyno graph of it currently? And have the adjustable cams been used to lower the power range?
Edit: What front pipes and cat back are you running?
Edited by Serpandrew
I'm not an RB26/GTR person but I'd look at it like this .
HKS effectively replaced the old "GT2540s" , which in todays speak are actually GT2876Rs , with turbos called GTRSs which are a GT2871R in 52 compressor trim .
People here say that it takes a specific combination of parts and good tuning to make GTRSs work on an RB26 and they actually use smaller but more modern compressor wheels than the old 2540s .
You could try all kinds of ways to work around those turbos but at the end of the day they are not a well though out turbocharger and you can do better .
Simply too big a compressor for the turbines to drive and thats what makes them lazy .
I think the designed for the purpose GT2859R (GTSS) are the go because they make boost and torque in the rev/speed range you can use in a street GTR .
Pretty sure you'd still make 300+ Kw but you'd drag the power range down possibly 1000 revs if not more .
So your call , either GTSS or inaptly called GT2530s I think .
A .
-9's are SS' s
-5' are close enough to 2530's.
Spend the money and rip those turbos off mate. You're about to drop a bomb of money and really, you're not gonna get the result you're after.
what are your cam gears dialled in as?
You could "possibly" get them to spool a tad earlier if you advanced the intake cams and retarded the exhaust cams a tad. A few people have gotten their GTS-ts to spool a tad earlier by retarding the exhaust cam gear only.
Hey guys
Firstly thanks for all your input on this matter - ill upload the tune soon.
Not to sure what's been improved from the cam gears other then an obvious lift on all parts on the graph.
I swapped out the gfb manual Bc and swapped it over for an eboost street and don't a few adjust I'm getting a rushing boost feeling from 3000 rpms and full boost at 4800 5000
Could they be 2530s? I also noticed an intercooler pipe leaking which I sorted out.
Lastly I spoke to my tuner and he explained how opts for a smooth graph and smooth power delivery. Maybe im just used to the standard response of the ceramic turbs?
Peak torque is 3/4 up the powerband, no wonder your not happy..
Im really with the others and will say spend wisely and just get real turbos. To match the peak you will need -5s. Check serial numbers before you do anything, obviously..
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
