Where's the best place you guys would recommend getting melatonin? After the last couple of weeks, particularly last night, I'm about ready to start slamming xanax - if only so I can fast forward through my f**king atrocious nights.
I just got mine through my doctor, didn't do anything for me though but everyone's different
50g of phenibut powder ordered.
Should I just rack it up in one go? That'll be completely safe yeah? Good.
You only want a small amount 300mg - 1g. initially to try. Thats about 1/4 small teaspoon at the most.
It's acidic , tastes like grapefruit juice concentrate. use lots of water.
haha all good Rev, was only joking :P Cheers though.
Seems the scoop it comes with should be roughly 300mg. Might crack out the milligram scales though, don't wanna f**k around with this stuff too much haha
Good to hear, I feel like driving the skyline into a tree at high speed, could actually do it in this weather too.
But don't do it :P I've felt that way about mine when I had it many many many times, only I felt that way because I hated the car - not because I felt like shite :P
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
