I actually had sleep last night!! Have not had a good nights sleep for almost 2 weeks. I am not sure if it was all the choc protein shakes but it has been terrible. Even GH bLast didn't work. Finally got some last night with the aid of valerian forte and melatonin 6x . ( Strange yet when I tried the gaba and phenibut the other day it did nothing ) I have stopped choc protein and gone to a different flav
My sleep has gone to shit the past week or so. I can get to sleep ok, but then wake up anywhere from about midnight to 3am, then it takes up to 2 hours to get back to sleep. I think it was because my normal sleep pattern was disrupted by the tour de France.......
I tried phenibut and melatonin last night; got to sleep quicker and only woke up once, but when I woke I was dripping in sweat. Had a few upsetting dreams last night not sure if related to phenibut/melatonin or not.
Melatonin would likely be responsible for the dreams. Why did you want to use both at once?
Took phenibut again last night; definitely sleeping better, got 6 hours which is the most I've slept in a few months. However when I wake up I'm dripping in sweat. This morning was worse than Sunday night, my hair is wet and clothes are dripping wet. I'm a bit concerned. I know other people here have taken phenibut, is this normal?
I've woken up nights in a row dripping in sweat when I've been having perfectly fine sleep and not supplementing anything (just to suggest it might not be related). I've actually almost concluded the reason I'm sweating is from lying in the one position for too long - but no idea why my body wasn't rolling over while I slept...meh
this used to happen to me during last year, no matter what the season (actually, not in summer) so the reason would not be overheating for me. I use the same blankets/doonas for all seasons so it's not like in winter i stack on extra layers either. very strange. also, sometimes it's just my legs/lower half of body that sweats, rarely is it my upper body too. also no supps except for protein i believe
Yeah I definitely wasn't overheating, that's for sure.
Easy test Leesh - stick with the phenibut for a week or so and see if sweating persists. If so, stop taking it for a week and see if sweating goes away. If sweating goes away, start taking it again just to confirm it's the cause (as in theory, sweating should return).
If it appears to be the cause, speak to yer docta ;)
Could it be due to an elevated immune response. Seeing that you are sleeping longer and more restfully could it be that your body has a better opportunity to heal and you immune system is working in overdrive. Just a thought.
possibly? I really have no idea.
Where's the best place you guys would recommend getting melatonin? After the last couple of weeks, particularly last night, I'm about ready to start slamming xanax - if only so I can fast forward through my f**king atrocious nights.
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
