haha all good Rev, was only joking :P Cheers though.
Seems the scoop it comes with should be roughly 300mg. Might crack out the milligram scales though, don't wanna f**k around with this stuff too much haha
Knew you would have a milligram scales...
amazing how for years i couldnt sleep. and i mean years of living on 3-4 hours a night.
now i just go to sleep. pop a little tv on in bed and im out with in an hour. also have a new bed which makes it even easier to drift off.
good stuff. sleep well guys!
My mattress was $1800. Everyone who has slept on it says it's amazing.
I get around 3 hours a sleep a night.
Last night: Went to bed at 12.30pm, went to sleep round 2.00am, woke up at 5.00am went back to sleep, woke up to my alarm at 6.15am. That's actually good for me.
haha yeah it's kinda the same here - my mattress would've been a super el'cheapo, but everyone who's slept on it reckons it's comfy as! I hate it though :unsure:
It's so unbelievably tempting to go out and blow a couple grand on a mattress...but I'm worried it won't make any difference :( bah!
Go buy one; you spend nearly 1/3 of your life on one, yet you'll spend 10k on a car that you spend an hour a day in...
My mattress cost $2500 and after considering the above, it's nothing in the scheme of things. Particularly when you get 15 years out of them versus a car. Whether or not it makes a difference to sleep quality, you should have a good mattress for your body.
I don't disagree for a second there bruz.....but that's $2500 I could spend on a trip to Canada for snooooooooowwwwww :P
I'll go have a looky this weekend i think, no excuses since Makin' Matresses is just around the corner from my gym (which is only 5 mins from home LOL)
Went out for a while last night to hang with my mate while he worked, as well as to purposely make myself extra sleepy...
well it worked haha, slept like a log...only just not for very long thanks to bed at 2am and alarm at 7. Oh well feel pretty good today.
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
