From what I understand all the claimed test booster do not boost testosterone they support the natural balance between test and estrogen. There is not artificial boosting at all. That ingredient macuna puriens helps with the balance. And if your test is high, lucky you because most of the 'normal range' levels sited by western medicine are too low. It has been proven that test from ancient non-westernized humans are close to double the level of westernized men. They also have non existent rates of heart disease, diabetes, obesity and hormonal issues we have. So I would not worry really because men with so called normal range test are less likely to create waves and a lot easier to control.... exactly what the government want.
fair enough, but I'm a female.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6902501
Ooops forget about the latter rant then. Out of interest what is the ratio between test and estrogen.
I'd have to tell you that when I'm at home.
So I'm still slightly confused as to what is an appropriate supplement for me to take
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6902652
Leesh.
Phenibut pure.
That Dorian Yates stuff is expensive repackaging, no points for guessing Mr Yates didn't get his huge size thanks to this stuff.
Don't think Dorian is a goal body shape for you ?
This is why I think the Yates powder is having a lend:
* It's not going to boost test (if it did it would be illegal).
* ZMA , called zinc tablets (when not being touted by muscle building supliment companies), is basically $6 for a bottle of 100 tablets from Cenovis, with the Zinc Magnesium & B vitamin ratios that work. IF you are deficient.
* Maca Puriens contains trace amounts of L-DOPA as it's claim to fame (so do ordinary broad beans), thats not a hormone balancer of any kind.
* GABA has a weak amount scientific evidence for it's effects, given it can't pass the blood brain barrier. So it's mechanism for efficacy is not known if it can work.
Phenibut can pass this barrier hence is evidenced as being effective and understanding of the mechanisim.
There is Phenibut in this stuff but, it's an undisclosed amount. That is the part that works.
Phenibut is about 3c to 12c a serve and works vs $2 - $4 a serve for the effective part.
Edited by rev210
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6903287
All the points above are valid however if you want to try an all in one sleep aid then I recommend this. Why? Because it actually does assist sleep. As with a lot of blends and also foods in general, the sum of the parts create different results than looking at the individual contents in isolation. For people not bothered to search for individual ingredients this is good to purchase. If you get results then search for the ingredients individually. And yes the claims are stupid as with any other body building supplement. $50 isn't a bad investment if it works, and it will work as it has for the 20 plus people I have recommended it to over the last 2 years.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6903603
I understand. You are quite right that it would assist sleep (contains Phenibut). I think you have a good point as Phenibut isn't an easy suppliment to find.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6903611
#@rev210
I'm looking at purchasing Phenibut from the Primaforce website; do you suggest the powder? There are tablets on there too but I don't think they're pure Phenibut, plus they have gelatin in them.
Just want to confirm the powder is what I should be getting before I purchase, thank you.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6911130
#@rev210
I got it from ebay. from this place.
http://www.ebay.com.au/itm/Phenibut-100g-Pure-Nootropic-Go-out-have-fun-dont-drink-Wicked-Gear-/290935953856?pt=LH_DefaultDomain_15&hash=item43bd2259c0
Taste is like very strong grapefruit juice (acidic) in water. It's only $36 for 100g. Bargain.
Edited by rev210
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6911836
I tried ronnie colemans resurrect pm but I think I have issues with the tryptophan in it as it gives me anxiety attacks ( I already take tryptophan during the day ) I have tried gh blast which has GABA included and that seems to help me alot better. Let me know how that powder works l33sh as at about $90 a tub of gh blast it sends me broke rather quick
Edited by Kenna802
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6926070
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
