I just been doing some research and found that phenibut can make people reliant on the drug and have some nasty side effects so everyone please be careful
Lets start by agreeing that anything that effects sleep is important to be careful with. Also , that almost anything we can eat may give certain people a reaction in a minority case.
I think your research needs some help. From what I can see , there is no 'real science' behind your statement. The research on the substance has been on-going for a long time and side effects are well documented.
Edited by rev210
https://www.sau.com.au/forums/topic/412794-sleeping/page/9/#findComment-6926591
I tried ronnie colemans resurrect pm but I think I have issues with the tryptophan in it as it gives me anxiety attacks ( I already take tryptophan during the day ) I have tried gh blast which has GABA included and that seems to help me alot better. Let me know how that powder works l33sh as at about $90 a tub of gh blast it sends me broke rather quick
You can get gaba cheap from bulknutients.com.au. together with arginine and glutamine I found it worked well. Good luck.
https://www.sau.com.au/forums/topic/412794-sleeping/page/9/#findComment-6926843
Just to get it straight the research I did was by google and alot of issues showed up. I have always had sleep issues and have found some to work straight away but only to have issues arising. The research I found was people begin to have to increase the drug in order for it to be effective but by than a lot of unwanted side effects came into play . I am not directing people not to take it only to be aware
https://www.sau.com.au/forums/topic/412794-sleeping/page/9/#findComment-6926924
Yeah this is with a lot if things mate. Especially when we are looking natural support supplements. Best thing I found is to cycle off every 4-6 weeks. So I found if you find 2 things that work you cycle them so your body doesn't get accustomed to one thereby rendering it less effective.
https://www.sau.com.au/forums/topic/412794-sleeping/page/9/#findComment-6926933
I guess I have been unlucky. I have been on AD's for over 5 years ( all different types too ) I have taken a different approach and trying more natural stuff in order to be myself. The long term effects of AD's are rather unknown as the newer ones are not very nice to come off of that's for sure. One thing I do know is that how I sleep depicts how I am for the day. Most sleep aids tell you to only take 5 days out of 7 and yeah GH Blast seems to work the best for me but it is the priciest :(
Also if you are on any SNRI's and SSRI's ( Anti Depressants ) Tryptophan, GABA, Some Sleep Aids, Some cold and Flu tablets or anything that raises your Serotonin levels can cause " Serotonin Syndrome " which can be Very Very Nasty
I would just like to point out these are my experiences with what I have come across and mock me if you wish but are directed at people whom are in the same boat as me and would just like to share my experiences so they don't make the same mistake.
https://www.sau.com.au/forums/topic/412794-sleeping/page/9/#findComment-6926975
no one is mocking you. Sharing your actual experiences are valuable. The most effective part of GH blast is the phenibut, the other component ingredients don't address the sleep. So the effectiveness of this experience you have had, is good for you to share. You have been effectively been taking phenibut.
Pure phenibut, would offer you a cost saving although sourcing and taste of product may be down sides for you.
https://www.sau.com.au/forums/topic/412794-sleeping/page/9/#findComment-6927000
Cheers for the advice guys I will look into the powders to save some coin . I have found prescribed sleep aids make you feel like u been on the piss all night. ( another thing I given up on the quest of life lol No alcohol for 6 months ). Gosh I have no life lol so been hitting the gym to try get myself in better shape although oddly enough I am shaped like a beer can anyways
https://www.sau.com.au/forums/topic/412794-sleeping/page/9/#findComment-6927482
Your not wrong about the taste yuck !! Tried gh blast and a scoop of l-glutamine last night before bed. Slept like a log. Only woke up once with my stupid body clock saying its time to go to work at 530 No work today !!! Sore as hell from last 2 workouts though I found I get way too jittery with 300mg of caffeine it's hard for me to use it without shaking like a leaf
https://www.sau.com.au/forums/topic/412794-sleeping/page/9/#findComment-6935300
Mine's horrific. Caffeine has something like a 7 hour half life in the body apparently, so I at least try not to have any after lunch lol
If that's the case that could explain a fair bit. I do notice if I have a coffee after 4-5pm I do stay awake longer during the night. That said when I was younger I could have a coffee half hour before bed and be out to it. ( always slept crap though )
https://www.sau.com.au/forums/topic/412794-sleeping/page/9/#findComment-6936021
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
