I am looking at wrecking my r33 if I have enough Interst in parts I will wreck it
The car has 96,000ks
This was a rebuild rb25det with forged internals with less then 2000ks on motor
Cp forged pistons
Scat rods
Arp bolts
Water pump
Timing belt
N1 oil pump
Stock cams
Stage 1 cams
Two heads one suit complete rebuild
Other one just had full service rebuild less then 2000ks
Ff plenum
80mm throttle body
High mount manifold
Hybrid turbo
Hybrid FMIC
Intercooler piping
Fuel regulator with adaptor for standard rail
Sard 850cc side feed injectors can come with fuel rail
Gearbox
Heavy duty clutch
Machine flywheel less then 2000ks
Cluster with 96,000ks
Two diffs
D2 coilovers
Bosch 044 pump
17inch shadow chrome rims
All panels, interior, headlights taillights
Everything this is a complete car if there is something you want let me know
Prices havnt been put up yet as I at work havnt worked out the prices just yet
Items are in Sydney for pick up can post some items
Series 1 front end,
No worrys will put prices up tonight for the above
Power FC ecu with hand controller $800
Hybrid intercooler $200
850cc injectors $500
Ff plenum $300
Why are you wrecking it?
Presuming it is crashed....
Interested in some items if the price is right, including engine but will need a lot more detail about who, what, when and where!
wrecking it as i dont have the time to put it all back together...
IT IS NOT SMASH OR ANYTHING EVERY SINGLE PANEL ON THIS R33 IS STRAIGHT I DONT EVEN THINK I SEEN A PARKING DENT IN IT...
yeah it would have that mate got nothing keen on the whole lot atm so if it falls thur ill wreck it, or if someone wants to take the whole thing then $5000 it has rego till end of jan 2013
apexi power fc with hand controller $800
Cp forged pistons
Scat rods
Arp bolts
Water pump
Timing belt
N1 oil pump
Stock cams
Stage 1 cams $500
head suits rebuild $100
other head was fully rebuilt and service less then 2000ks ago $400
Ff plenum $300
80mm throttle body $100
High mount manifold with external wastegate $300
Hybrid turbo has shaft play could do with rebuild $300
Hybrid FMIC $250
Intercooler piping
Fuel regulator with adaptor for standard rail $150
Sard 850cc side feed injectors can come with fuel rail $500
Gearbox $1000
Heavy duty clutch $300
Machine flywheel less then 2000ks $300
Cluster with 96,000ks $200
Two diffs $100 each
D2 coilovers $500
Bosch 044 pump $100
17inch shadow chrome rims brand new tyres on front rear has about 60% $500
something are not priced yet will take offers on them
TAKE THE HOLE CAR FOR $5000
Couple of people are Intersted in the car has a whole, ill let yous know by mid next week if I'm parting it out
But if you still want parts still pm me as when I wreck it I can contact you
Parts that are up for sale ATM are
Ff plenum $300 Ono
17inch shadow chrome rims and tyres in above pic $500ono
Drift boost tap controller $40
Oil gauge with sender $20
1 complete head prob suit rebuild $100ono
Hybrid turbo-was working before remove has some shaft play $200ono
Clutch fan- fins trimmed already for intercooler $50
Disregard the first post....
Items that are for sale are listed below
Pff plenum $300 Ono can supply throttle body for extra cost
17inch shadow chrome rims and tyres $400 Ono
Clutch fan $50
Hybrid turbo $200 Ono
6x injectors in a fuel rail said to be nismo gtr injectors
Ill get numbers on the injector and confirm what cc these are
Open to all offers mates
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
    • Hi. Which coilpacks can i use in my engine? I looked at the Splitfire but the closest "match" i found was SP-DIS-008 but even that they do not show RB20DE NEO so iam not 100% sure. Or maybe different one which will 100% work? I saw many on ebay but they are some cheap "strange" ones. What about Yellow Jackets? Many thanks 🙂
