R34 Xennonon head lights $400 pair as some damage to the housings
· R34 4 door tail lights $100 each
· R34 front bar Indicators $40 each
· R34 Dash wit hall vents $300
· R34 Carbon bonnet $400
· R34 4 door Boot lid with no spoiler or holes $250
· R34 4 complete doors $250 each
· R34 Bare front cut shell $500
· R34 Front guards $120 each
· NA R34 Front bumper with custom lip $150
· R34 Non abs rear cradle no diff all factory arms $500
· R33 Series 2 power fc $600
· R33 Series 2 rb25 complete engine package $1500 loom afm turbo (no gearbox)
· Apexi copper radiator $300
· R34 manual conversion $2500 exedy single plate clutch
· Nismo R34 boss kit and steering wheel $150
· R34 Cusco front & rear sway bars $450
· R34 Red east bear recyclable on drivers rail $400
· R34 Std passenger $100 and rear seat $100
· Full set of R33 GTR rims tyres are bald $800
SMS THE NUMBER FOR INFO NOT ON HERE MUCH ANY MORE
  • 4 weeks later...
  • 1 month later...
  • 1 month later...
Bump still got all 4 doors rear bar rear seat and passenger seat sitting at my house make a offer SA sales preferred
mesg me on 041 1152733 for these bits
all other parts queries use the number in the first post
Edited by 1400r
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
