so guys and gals, I know it hasn't been to long since are last cruise but the weather is good and is the season and jet r 31 and myself going on the smasa cruise put me in the mood so looking at doing a. cruise end of Nov for xmas. so hands up who would be keen.
cheers
Jase
https://www.sau.com.au/forums/topic/412862-sa-xmas-cruise/
sooo was thinking sat night cruise or Sunday day cruise? was looking at the weekend of the 17/18th b4 everyone gets to busy with work xmas shows and stuff, aswell as after that my cruise routes will be in ever diminishing circles around the hospital as our next little bundle of joy will be due any tick of the clock
https://www.sau.com.au/forums/topic/412862-sa-xmas-cruise/#findComment-6607386
Is that 17/18 of Movember? If so I'm out, I'll be at Rally Victoria.
https://www.sau.com.au/forums/topic/412862-sa-xmas-cruise/#findComment-6607399
