I just got my 350 just over a week ago and car only dont about 60000ks on it .i am just wondering what are the things that can go wrong wit the engine? and i need to do more homework on apart from electrics > thanks .
https://www.sau.com.au/forums/topic/412868-thing-can-go-wrong-with-the-engine/
If its a new car to you and you don't know the service history - at this stage all you should worry about is doing an oil and filter change - spark plugs, and if there is no evidence of genuine km's, you might want to prepare to change the drive belts soon.
Other than that preventative maintenance, if it aint broke don't fix it.
Edited by SMOKEYC34
i never assume that someone has done the work even if it has receipts, its easy to knock up fake papers... same goes with odometer readings - theyre easy to wind back if needed.
when you buy a second hand car, replace and FLUSH OUT every fluid - engine oil, coolant, trans, diff, brakes, power steer. all filters.
i did all of this and still had my gearbox die a year later thru normal use. a $3000 repair due to a $10 clip breaking
what you mean $10 clip breaking ? yeah bought it from a dealer call jap auto worlds seem like all the fluids are new my macheanic checked it . car seem to be fairly new engine seem to have no problem at all just worried about things that can go wrong so i am prepared for it .
The sky could fall.
Like the guys have said, drop all fluids and replace with good quality synthetics. Change the engine oil every 5000 and learn to do it yourself Allen so you know it's done properly.
Last oil I bought was 20L of synX 6000 for $120, that will last you a year or so.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
