  • Replies 46
take a while to respond to emails but reasonably helpful
A lot of places are the same (myself included) but if you ever call up Jamie is EXTREMELY nice and helpful.
In fact they are getting my old (and the missus' current) Legnum on Wednesday for some lurve.
They are expensive but they seem very thorough and I'm sure they would do a proper tune.
ie not just a WOT tune for power
As I drive this car a lot for work I want a proper all round tune which does take a long time to do properly so I still will consider taking it to them.
They seem very professional and thorough
But yeah $1700 is a lot of money for a tune
Yeh dude, any good workshop will do a 'proper' tune though. I've never had a problem with any of the tunes I've had at Allstar, Hyperdrive, or Garage 101. My car idles almost like factory apart from the slight note from the cams, and that's with 1000cc injectors. And I've been getting 550-600km's to a tank of petrol for awhile now.
Edited by Hanaldo
Where did you get your car tuned last time ????
How do you get such good mileage even with cams and 1000cc injectors?!
I've got an S1 25det with power fc, GTRS turbo, 740cc injectors, pod, fmic, full exhaust, nismo fpr and i only get max about 360-380 usually in a 32 with a lot of highway driving. Tuned at Allstar after turbo kit was installed. This was during previous owner, have receipts. Oxygen sensor seems to be with voltage spec according to hand controller readouts.
There's your issue. Ditch the O2 sensor and lean out the cruise mixtures. Biggest fuel saving is the boost transition cells and the throttle enrichment, if you can get your tuner to spend a bit of time getting those set up well then you'll get decent economy. I actually get worse economy driving on the freeway or anywhere around 100-110km/h, the engine just revs too high. I get best economy just driving around town at 60-80km/h.
I get around 9L/100 with O2 feedback turned on.
I do 298km a day to work and it generally takes just under 30L
I've got cams and nismo 740s on power FC. Even during the 1200km run in period before tuning it didn't use any extra. I almost never get onto boost going to work.
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
