Ok, recently my RB26 dropped a valve and destroyed the engine I had in my R34 GTT, was making over 500hp, probably closer to 600, but anyway, that engine lost a piston and the N1 block cracked.
I've sourced an R33 GTR motor to use for now to get my car up and running again.
I've got it sitting on an engine stand right now and just wanted to see what's people's views and opinions on what I should do before I fit it to my car.
Ok, from what I gather about the previous owner of the stock RB26 is that it had 100,000kms on a stock GTR, standard boost, and it was just serviced, he then built a new engine as a tax write off and put this on the shelf.
So I have a built rb26 that is destroyed sitting there and a stock 26 that's going to replace it for now.
I'll be detuning to suit, lower rev limit, less timing, less boost, but was thinking is it worth it to put the Nitto oil pump from the other motor in it?
What about the ext head drain oil kit?
I'll be bolting up the inlet setup and the exhaust - 6boost manifold, tial 60mm gate and a gt3582r.
And the larger 8L custom baffled sump too.
I was thinking of taking a main and big end off to inspect them, and replace if required which it shouldn't need hopefully.
What else should I do, I'm not really keen on stripping the motor, If I did I may as well just aource anothe JE piston, Along with fit the eagle rods and modded crank, rebuild the old head and be done with it.
I plan on doing that later to another block.
Ive read the nitto pump needs the restrictor put in the head oil feed gallery or its too much oil up there, if I'm only revving to say 7,500rpm, is a stock one sufficient for 300+kws or should I fit the nitto one along with the ext oil drain kit or will it still flood the head with oil?
Can you take a spring out to reduce the pressure?
Depends on use I suppose, if its gonna be given hell then all the oil mods would be advised, the nitto pump flows 60ish lph from memory so that would empty out a stock sump quicker than a stock pump would, hence the need accompany it with the bigger sump and restrictor. Enlarged oil returns/external drain etc by that stage you've already got a decent amount apart and would be seem like a waste of time/labour/money to come back and install forged pistons and rods at a later date. If it's just a streeter then you should be able to get away with the stock motor and pump, wouldn't hurt to install the sump though.
The less revs the better.
Edit: nevermind, just saw now youre running a single. Regardless, if you want the motor to live, be sensible with the revs
Edited by RB2600
Gonna keep it stock for now, keep the revs to 7,500rpm, back the boost down a bit and see how it goes.
I figured if I don't rev the motor, the stock pump will be fine.
I'll keep all the good bits and build up an RB30 bottom end to suit my worked head and then throw that in at a much later stage.
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
