Hi All,
I just had some paint work done on my R34 GTR and since I picked it up, when I remove the key from the ignition, the car does not turn off and the engine keeps running.
When I picked it up I noticed the engine bay was very wet, so when they hosed the engine bay not sure if they have caused a short or if this is irrelevant.
To turn the car off, I have been putting it in to a stall, and when the key is removed the car stays in 'reds', lights on in the dash as if the key was half turned. And it eventually turns off after a few minutes.
Confirmed with the shop that the battery has not gone flat, they have not had to jump start - etc.
Would appreciate any direction as to what could be causing this.
Cheers.
Just an uneducated guess.
Water pooled in the wires/connectors under the main fuse box in the engine bay causing a connection to remain live even though turned off.
Perhaps the use of a hair drier on warm in that area and/or some WD40 to displace any remaining water.
I expect over time it will return to normal if it is water related. However I would want it working as it should now.
What a pain mate.
Question: What did they paint ?
Thanks guys for such a quick response and your help.
I took the car to Carbon Car Systems in blacktown this morning and you are right. Quick diagnosis confirmed that it was the turbo timer in the alarm which had been activated. (Which I did not even know the alarm had so was a welcome surprise).
Painters must have accidently activated it with the remote when the car was in their posession and the feature is set to stay on until disabled with the remote.
Cheers.
What alarm is it? Mongoose's new models have turbo timer built-in. Default is 2 minutes though, maximum is 5. Should turn off after 2 minutes if programming hasn't been changed. To disable, you normally press button 3 with the car running and you'll hear the siren chirp to confirm whether it's on or off.
  • 3 weeks later...
Have you got a mongoose m80?
I know its been resolved but for future reference all you do is put the key in and turn it to on, then press "button 3" on the remote and it beeps once or twice going through turbo timer on/off function. Can't remember which is which though.
thats friggin gay, everything is illegal in australia. Might as well just stay in bed. soon that will be illegal too.
Turbo timers are illegal because it is illegal to leave a car running whilst not in it. This makes sense as it isn't safe having a locked car running, because if it was to somehow get knocked into gear it would just drive off. It is also safer to have a car parked both in gear and with the handbrake on. Turbo timers being illegal was never about spoiling import owners fun.
I believe a ADR classification says that the alarm has to have a certain amount of function/protection.
As stated by the insurance company.
It has to have multiple points of immobilisation
Black wiring
Central locking
Motion/disruption sensors
Automatic immobilisation if the car is left unattended
And some other things i cant remember.
This information was given from justcar when i asked them what classes a adr approved alarm.
Black wiring
Central locking
Makes more sense
Must be fun to wire them up with all black wiring :nyaanyaa:
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
