Stock R33 S2 Suspension All Shocks And Springs
I found two used throttle bodies both claiming to be from a R33 RB25DET, I bought both, when one showed up it has a large center rod with a flat side for the center drive of the TPS. The other has a much smaller center rod with a smaller cross rod through it making a "X".....this style matches what my rb25det neo engine has, so I will be able to use this throttle body and my org wiring and reuse the sensor itself. I don't know why the other has the other version (both said TB from S2) but no matter I was glad I ordered both, as I found one that will work nicely.
All of that material you found hard to remove is hard to remove for a reason. If the factory could get away with using paint I'm sure they would. If I was doing the repair, I'd be looking to replace the sealant I had just removed with something equitant or better. -
its not really a truck bed liner
No, i used Rust Encapsulator Plus. https://www.eastwood.com/eastwood-rust-encapsulator-plus-quart.html?gad_source=1&gclid=Cj0KCQjwo8S3BhDeARIsAFRmkONxM27m1gqntP8Uw-ktrfx9g2Eq_UtGGcqlM0Sn3sYdcU1RyivLnNEaAi7LEALw_wcB&wcid=18675710285&wickedid=657100129148&wickedsource=google&wv=4
1.80 yen for a slice of pizza... or is it supposed to be 180 yen?? Unfortunately it was the latter 😢 Didn't try it because we'd just left a Kobe beef restaurant and had no intention of going for a slice of pizza. 2 Bros Pizza at Hankyu Sannomiya station: https://g.co/kgs/HrVzGV8
