JordansR32 Posted November 3, 2012 Share Posted November 3, 2012 Hey guys, just got a problem hoping someone can help me with it or point me in the right direction to get it fixed. I have a rb20 with a turbo from hypergear, nistune ecu, injectors, front mount, full exhaust all the usual mods, when i rev it out from 1st gear to second gear in high rpm it bogs down/lag and then the power kicks back in once ur in second gear, its almost feels like u slam on the brakes inbetween the gear change. Uts getting really annoying and i dont know what it could be, i thought it could be the BOV, coz i had it blocked off so i thought it might have been the air going back out the turbo slowing the wheel down but unblocked it and it still does it, i also have the pipe that comes off the BOV just pointing into the engine bay, not back into the intake, its still a stock BOV aswell. If anyone could help me out that would be much appreciated. Link to comment https://www.sau.com.au/forums/topic/412962-rb20-lag-bog-down-high-rpm/ Share on other sites More sharing options...
Got a Pulsar Posted November 3, 2012 Share Posted November 3, 2012 i also have the pipe that comes off the BOV just pointing into the engine bay, not back into the intake, Do you mean where the plumb back pipe connects into the intake pipe, it's not connected? So you are sucking air into the turbo through the hole in the side of the intake pipe? Air that is unfiltered and also not measured by the AFM? This would be a problem me thinks... Link to comment https://www.sau.com.au/forums/topic/412962-rb20-lag-bog-down-high-rpm/#findComment-6607793 Share on other sites More sharing options...
JordansR32 Posted November 3, 2012 Author Share Posted November 3, 2012 Air cant go back through that pipe coz the BOV will be closed so how will air go back through it? It done it also still with a aftermarket BOV with a trumpet end aswell Link to comment https://www.sau.com.au/forums/topic/412962-rb20-lag-bog-down-high-rpm/#findComment-6607810 Share on other sites More sharing options...
Got a Pulsar Posted November 3, 2012 Share Posted November 3, 2012 The Bov plumb back pipe, it's not attached to the Bov right? Is the other end still attached to the intake pipe between the AFM and the Turbo? Have you blocked any of the open pipes? Link to comment https://www.sau.com.au/forums/topic/412962-rb20-lag-bog-down-high-rpm/#findComment-6607832 Share on other sites More sharing options...
JordansR32 Posted November 3, 2012 Author Share Posted November 3, 2012 Its just the normal stock BOV and the pipe that from the trumpet bit of it just goes to no where to the engine bay, it used to go to some pipe which took it back to the intake for the emision reasons, but since upgrading to another turbo i had to get rid of all that so that bit of pipe just vents to the engine bay, and no other pipes have been blocked either Link to comment https://www.sau.com.au/forums/topic/412962-rb20-lag-bog-down-high-rpm/#findComment-6608085 Share on other sites More sharing options...
scotty nm35 Posted November 3, 2012 Share Posted November 3, 2012 Lol, emissions reasons... And perhaps it's required? The AFM thinks there is more air entering the engine than there actually is, hence the fuel dump and general crappy running engine. Link to comment https://www.sau.com.au/forums/topic/412962-rb20-lag-bog-down-high-rpm/#findComment-6608093 Share on other sites More sharing options...
JordansR32 Posted November 4, 2012 Author Share Posted November 4, 2012 Its only done it just after i got a tune Link to comment https://www.sau.com.au/forums/topic/412962-rb20-lag-bog-down-high-rpm/#findComment-6608533 Share on other sites More sharing options...
DVS JEZ Posted November 4, 2012 Share Posted November 4, 2012 Blame the tuner Waiting on NIStunes reply. They emailed today. Hopefuly have a few answers tomorrow Link to comment https://www.sau.com.au/forums/topic/412962-rb20-lag-bog-down-high-rpm/#findComment-6609008 Share on other sites More sharing options...
hypergear Posted November 4, 2012 Share Posted November 4, 2012 I also had this problem on the R33, happens the air doses backwards onto the AFM. It was fixed by relocating the afm into the cooler piping. Link to comment https://www.sau.com.au/forums/topic/412962-rb20-lag-bog-down-high-rpm/#findComment-6609125 Share on other sites More sharing options...
STATUS Posted November 4, 2012 Share Posted November 4, 2012 Blame the tuner Waiting on NIStunes reply. They emailed today. Hopefuly have a few answers tomorrow send it through if you need a quick reply, have the tuning lappy at home tonight. Link to comment https://www.sau.com.au/forums/topic/412962-rb20-lag-bog-down-high-rpm/#findComment-6609252 Share on other sites More sharing options...
DVS JEZ Posted November 4, 2012 Share Posted November 4, 2012 send it through if you need a quick reply, have the tuning lappy at home tonight. Cheers Link to comment https://www.sau.com.au/forums/topic/412962-rb20-lag-bog-down-high-rpm/#findComment-6609527 Share on other sites More sharing options...
DVS JEZ Posted November 4, 2012 Share Posted November 4, 2012 I also had this problem on the R33, happens the air doses backwards onto the AFM. It was fixed by relocating the afm into the cooler piping. Definatey seems like the same issue, and to clear things up its not a lag issue, its a hesitation Link to comment https://www.sau.com.au/forums/topic/412962-rb20-lag-bog-down-high-rpm/#findComment-6609547 Share on other sites More sharing options...
