Hi,
Is it recommended to change the pivot ball when installing a heavier clutch. I am reading different opinions everywhere.
And if you were to change it where would you find the nismo pivot ball for R34 GTT ? Would it be the same one that was compatible with the R33 GTST ?
The code was 30537-RS581 or the RS540 one but no where does it mention R34.
Thanks
https://www.sau.com.au/forums/topic/412972-pivot-ball-for-r34gtt/
  • 3 weeks later...
R34's have a Pull type Clutch. You won't have a pivot ball.
as can be seen here.
Be careful that you get a clutch that is Pull. You will notice in the pic that the push type pivots on the 'pivot ball', and the pull has a clevis and pin arrangement.
