  • 4 months later...
He Guys...looking in my DNA Garage^^ The Omori S1 Factory from my Friend Steve stay in the moment in my Garage for repair.....shit ****ing electrik -.-
my BNR32 is on the Final Finishing Phase^^ I love this Garage look^^
  • 1 year later...
Thank you all so much for the nice comments and the compliments! But I have so much to do :) The Winter is comming :D The Carbon Manifold and Hot Pipe are Self-and Handmade Custom Style :)
@Terry...you are welcome at whatever time you like :) but i don´t life in Bavaria...I´m in the near from Dresden/Chemnitz in East Germany..not so far away but in Saxonia :D
  • 9 months later...
He Guys! It has been a long time since I write my last post. Have made "some" things since last year :D
Hope you like it ;) I'd be interested in knowing what you think about this Style :) The Wheels are complete Custom and Handbuild (Center also)
Fitment is still working in progress and finish next week for Wörtherseetour ;)
Carbon Side Skirts for Protect the Original :)
Edited by Toho
  • Like 4
  • 3 weeks later...
  • 5 months later...
The Last Update in 2k15 xD (now with Rocket Dancer^^)
It was Season End and my Beauty sleep now....This Winter my Body get a complete restoration (small things but i can´t life with THAT xD)
Here a small Article about my Car.....
Day for Day...its a Honor to meet People with THIS positive vibes and share the same Passions. One big Skyline/GTR family around the world <3
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
