Greddy/trust Sump Extension - Your Thoughts?
Shoota_77
 Share
Hey guys, I'm thinking about welding on a Greddy/Trust sump extension while the engine is out of my car.
Has anyone done one and have any feedback on it?
Does it make engine refit a prick? Was it difficult to get it to lined up for welding?
Any feedback would be awesome. Very little info on here or the web.
Cheers,
Ewan.
Not too sure about the trust one but I had a Hi-Octane one welded onto my 26 sump and it doesnt have any clearance issues at all. I'm fairly sure the trust one would be the same but you should get someone who knows what their doing to fit it just to make sure it's in the right place.
Seems pretty cheap to me. $425 delivered.
Unless you just got a fabricator to make one and hope it works you're looking at well over $1000 change over for any of the recognised guys to do one (Hi Octane, Mercury, etc).
I'd do the cutting and just get it tigged somewhere that specialises in ali welding. Should only add $200 max extra.
are you doing the welding yourself???
if not, factor in that a welder will charge around $80/h plus cleaning and prep costs, materials for welding
alot of people including myself use the micks metal craft or hi octane extensions, they are a realy nice bit of gear
This is a good point, it'll need baking to remove oils etc from the metal and dont attempt to cut it up unless you know exactly what penetration gaps/prepping it'll need as you may very well make it harder to do. That price aint bad for that. Expect to pay 150 for ordinary job, 250 for baking prepping and welding.. Over 300 and they're having you
I went through the hassle of this not long ago if ur running a high vol oil pump eg tomei, the trust ext is shit you will be best off paying Racepace $1500 for their 9ltr sump includes extended pickup and fittings for drain/ breathers
If standard the trust extension is prolly an upgrade but waist of time in my eyes
Yep I brought one. Never fitted it, they don't hold that much more oil. And they hang down heaps low. I ended up getting a race pace sump. Haven't fitted it yet, but fark they a work of art
Hey guys, thanks for the info.
Uwissh- Not trying to be a smartarse but my post above yours is pretty clear about the welding. If I do end up doing it, I'll see how my alloy tigging skills are and I might make an additional side section to replace the baffled bit on the side on the std sump. I'll make it then get it welded on by a pro. I bought the alloy to do for all of $5 from the scrap metal joint the other day. It's 4mm thick so should be strong enough.
Where do you stop money wise??? That's always a consideration. I intend to track the car once I eventually get it back together but it might be 2, maybe 3 times a year max. I know it only takes one gut full of air to kill the whole engine but it's risk versus expense i guess!
I'm a poor man playing in a rich mans game.....
my bad, didnt read that part,
unless your really good at alluminium tig welding or tig welding in general i wouldnt even try to attempt it yourself, has to be done spot on, able to with stand pressure and also be pressure tested to ensure your not going to have any leaks.
as nismoid said, if you intend on tracking it then y would u do a half assed job, get it done correct 1st time n have some peace of mind
I would give it a go, im not the worlds best tigger, but i did mine out of 6mm, with 12mm plate for the sump plug area, just make sure you bolt it to a block when you tack it and outside weld it, then remove and inside weld it.
Edited by Adriano
I'm pritty sure, you gotta heat the sump up super hot before you start the welding. Just get a workshop to weld it. You want it done right, can u imagine doing it yourself and its not done right, pulling the motor out, fitting it, and than putting the motor back in only to find it leaks, or cracks on your first launch. The sump has a fark load of force going though it, if its not done right, you will break weaken it. Also make sure it's bolted down to somthing flat and left there to cold right down, so it don't twist or do anything crazy.
Someone has said (tuner or engine builder) that they've dealt with some dodgy "custom" RB oil sumps that have lunched acouple engines due to poor design. I assumed it was the Hi-Octane ones?
we made our own winged ext. like the Hi-octane ones, out of 4mm plate and made a swing gate baffle and ext pick up. had it welded on by a pro, no baking, etc, just a good tig welder. never had any issues.. its definately doable if your a half decent welder, just leak test it with the special dye ( forget what its called, but really thin stuff that shows the finest seep ) also we didn't take the diff out and no probs.
My current car has the Trust ext. and it does sit a bit low, low enough that I've worn off the bottom edge of the sump plug, and it doesn't hold much more than standard, but it has seen plenty of track and works.
 Share
    • There are a few variables here, some are relevant but not critical (IMHO) to help answer your question. The two major things: 1) Ignoring anything to do with forced induction - all engines have their own natural torque curve, and it will ALWAYS roll over higher in the rpm.  There is a fixed relationship between power and torque.  When dealing with kw and nm, the relationship between them is roughly: kw = (rpm * nm) / 9549 nm = (kw / rpm) * 9549 The peak torque of an engine (without boost) will typically climb until somewhere nearish the middle of it's operating rev range, give or take a bit - then start dropping again.   The nearer the minimum and maximum rpm of the engine the steeper that drop off tends to be. 2) Boost simply increases the density of the air going into the engine, which inflates the torque at that point.  The ramp up in the torque curve you see on a turbo engine is due to the boost rising, but it's essentially just multiplying the torque you'd see if it was naturally aspirated.  The roll over you see at the end will typically be what would have always happened with the engine, whether it was naturally aspirated or turbocharged.   If the torque never started dropping then power would climb infinitely. The cool thing about this is you absolutely can tune the power delivery to suit the needs of the owner and/or the limitations of the car, and I regularly do this.    With modern turbos we've got to the point where a setup that someone may run well over 20psi of boost with could actually reach target boost well under 4000rpm if the tuner/owner WANTED to - and a lot of people seem to do this when there is actually no realistic benefit, generally it just adds a massive amount of strain to the engine and drivetrain and often actually makes the car harder to drive. As a general rule I tend to tune the boost curves for cars I tune to reach a "useful" torque level through the rev range and will often end up with a curve that ramps hard to a point, then creeps for the rest of the rev range - not to make the boost curve "soft" as such, but more to make sure its neither laggy nor pointlessly violent in it's delivery.   There have been cars I've tuned to be almost like a centrifugal supercharger (or naturally-aspirated-ish) where they actually only hit like 8psi of boost before opening the gate, then ramp up the next 10psi over the rev range... if the car is "loose enough" to drive. On the flip side I've tuned a car that had stock cams and the engine's natural torque curve fell over HARD in the higher rpm and resulted in a slightly awkward power curve to work with, in that case I actually started ramping up boost to boost torque in a way to offset the engines "NA" torque drop off... at peak rpm actually running a good 5psi+ more boost that what the "flat curve" would have defined.  This gave the owner an extra 500rpm or so of useable rev range, and had a fairly solid impact on times he was running at motorsport events due to being able to hold gears a bit longer and also falling into a more useful part of the rev range in the following gears. Here's an example of an RB in a GTSt I've done the "softened" boost curve to not pointlessly ramp straight to the max boost target early in the rpm, but still made sure it builds useful boost.  If you went in the car you'd not guess at all that the boost curve was doing anything "weird", it feels like it spools immediately and accelerates relentlessly (traction dependent) and holds to max rpm.   I don't know if you'd guess what the boost curve was doing by driving the car, or even looking at the dyno plot... but imho it suits the combination.
    • therefore on the first examples, as we see, changing cams (graph 2) influences the quantity of torque at high revs its OK for me. so a tuner can act on the wastegate via the boost controller to increase the boost at high revs? on the last example, the boost does not decrease ok, but the torque does. this can come from cams etc etc ok. but on the other curves the boost is not constant, it increases, this is what I find strange to my mind. even more so if it comes from the relief valve. sorry I'm very new don't blame me. in my mind I couldn't imagine how the boost could be higher after the spool
    • right, but fundamentally, for a given mechanical setup, you are either using all the torque (and therefore power) it will give, or you are choosing to run it less efficiently. Many tuners will have a practice of identifying peak available torque and then winding it back a couple of % for safety, but unless you are working around a very specific issue like a weak gearbox, there is nothing to be gained by making 20 or 30% less than the engine can
    • You can manipulate the torque delivery by ramping in boost gently, then throwing it all in after peak torque to keep the torque flat. It's nothing magical.
    • Tuning the wastegate to do it. That is all. Most people want the boost to not fall off like the most recent example. Those also look like dyno runs with an Auto/Torque converter setup, which does fun things to the graph. The boost tapers down like that because the turbo cannot supply the same amount of air at 7000rpm that it can at 3000 in terms of PSI. That, or the tuner has decided that it tapering off like that is what someone chose to do. IF you have a wastegate that can't bleed enough air to slow the turbine, and IF that turbo can flow enough air to feed the engine at high RPM, you get 'boost creep' which is a rise of boost pressure beyond what you are capable of controlling and/or want. None of these show symptoms of that, but if you had a run that was 20psi at 3000rpm, and 27psi at 7000rpm, it could be an example of that. Or simply that the person wanted boost later for their own reasons... The dyno graphs don't always show the full context.
